Cornucopia of CEL Codes
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Cornucopia of CEL Codes in Cadillac SRX / XT5 Forums; 2005 SRX 3.6 V6 2wd, 99k Two weeks ago I had a P0496 code pop up. After replacing Purge Solenoid ...
    jmanny is offline Cadillac Owners Member
    Automobile(s): 2005 SRX
    Jul 2013
    15
    Two weeks ago I had a P0496 code pop up. After replacing Purge Solenoid in engine compartment the code cleared on it's own. I replaced a loose gas cap also.
    This past Saturday, I was stopped at a light and engine began to run rough and CEL was flashing. This lasted less than a minute and did not come back until this morning while merging onto the interstate, luckily the traffic was backed up and I didn't have to floor it. CEL light flashed but no solid light. Again it lasted less than a minute.
    Went to Auto Zone this afternoon and had them pull any stored codes.
    I have the following codes:
    P0202
    P0300
    P0302
    I researched the flashing CEL and came up with a misfire situation. So I planned on replacing plugs this weekend and hoped that the CEL would stay lit so I could pinpoint what coil may need to be replaced. After looking at the codes, I would like to ask the experts for some help on possibly nailing down what the issue is.
    On an unrelated (maybe) note when I unlocked the car using the remote this morning, the radio came on at the same time without me even putting the key in. This afternoon while at Auto Zone after reading codes and removing key and shutting the door the radio stayed on again....I am thinking this may be haunted with electrical problems......At least the engine doesn't burn excessive oil, LOL
    Any help or guidance is appreciated.
    John
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: Cornucopia of CEL Codes
    300 &302 are misfire. 202 is injector control circuit, cyl 2 (causing misfire cyl 2). Probably wiring related. Look for shorted (bare wire) in harness near injector or where it might rub. If you can't find anything, I can help with more detailed diagnostics.
    BTW, that's front cyl, driver side.
    Been fixin' cars for 74 years
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    I'm curious with the p0300 also could be something else fuel or computer related. When we're the plugs and or fuel filter changed? I've dealt with injector issues with these before and ended up being an ecu.
    Jul 2013
    15
    I purchased the SRX in July, it didn't have any service records at all so I have no idea when/if the plugs have been changed. My guess is they haven't. I plan on changing them over the weekend. I'll check the wiring for the injector then. I was wondering if I should just go ahead and change out the coil for cylinder 2 along with the plug since I am getting the misfire code for that cyl.
    I was also curious as to why it threw the P0300 code. I figured if it was a bad coil or misfire it would only throw the code for that cylinder.
    When I get it apart and check the wiring, I'll post if I can't find any bare wires or shorts.
    Thanks for the replies, much appreciated
    Oct 2012
    975
    New plugs could cure the entire ordeal except the injector issue. Check to see if it is spraying correctly.
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    37
    144
    Quote Originally Posted by jmanny
    Swapping the coil to another cylinder and getting the same code will rule out the coil. Then you can focus on wiring as Blake mentioned Etc.
    Changing (or at least inspecting) each plug is a good idea if you dont know the history record. Check for fouling.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,833
    300 is a general misfire code, usually comes up when a specific code appears. You can ignore it.
    Jul 2013
    15
    Thanks for all the suggestions. I will change the plugs and the coil for cyl. 2 then I inspect all the wiring for the injector. I'll update the post afterwards.
    mjcaddy's Avatar
    mjcaddy is offline Cadillac Owners Fanatic
    Automobile(s): 09 1SG STS4 & Subie CrossTrek (retired 03 DeVille & 05 V6 SRX4)
    Oct 2010
    Chicagoland
    32
    421
    change the plug and the coil for cy2, if it still exist then it's ECM, I had it replaced on my 05 SRX V6 @99k miles, I had the exact same symptoms except mine was a different cylinder code.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,833
    Why so eager to replace parts that have not been identified as bad? The days of replacing plugs/coils for a miss are over. Your code says the INJECTOR circuit is the problem, and ONLY cyl.2 injector. Start there.
    Oct 2012
    975
    Quote Originally Posted by glake89 View Post
    What about the random misfire #2 injector wouldn't have anything to do with the rest of the cylinders.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,833
    Code 300 is "misfire detected", not random, unless no other misfire codes.
    mjcaddy's Avatar
    Oct 2010
    Chicagoland
    32
    421
    The only reason I recommended to replace them because both coil+plug are about 65-70 bucks if he want to buy them and not just replace them with another one from a different cylinder, I'd rather change those and see if the problem get fixed, versus going to the dealer to charge them $130 just for the check.
  16. #14
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    333
    When I knew I had a bad coil, I went to pep boys to see what it would take for me to get a diagnostic so I could have my warranty cover it. If you go in with an engine light on, it's $44 for a diagnostic and they waive the fee if you get the work done there. It's $88 for a diagnostic without the engine light. At least where I live.
  17. #15
    Jul 2013
    15
    Well, I changed the plugs and the coil that was coming up as bad. Still misfiring. Troubleshooting shorts or wiring issues is not something I am comfortable with so it is currently in the shop for diagnosis. I am waiting to see what the verdict is.
  18. Remove Advertisements
