oil leaked.. change or add?
Results 1 to 14 of 14
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, oil leaked.. change or add? in Cadillac SRX / XT5 Forums; 2007 srx V8. I came out the other morning and below was about a 18 inch wide oil spot.. at ...
    jgodfrey82 is offline Cadillac Owners Member
    Automobile(s): 07 SRX NorthStar - just purchased, and loving it!
    Jul 2011
    71
    2007 srx V8. I came out the other morning and below was about a 18 inch wide oil spot.. at first I thought it looked red, but I think that is just concrete of my driveway and it is just oil.
    I crawled under and the only thing I saw was some drips off the oil filter and it felt somewhat loose. I tightened it up and parked in a different spot and haven't seen any new dripping. The mobil1 is only about 3k old, and even though I have the next 8 quarts sitting in the garage I dont want to waste.
    My dipstick seems to be wet and full when I pull it out, but it is the weird hex design dipstick, so I dont really trust it. I feel like my motor is missing some compression at low speeds, not dramatically, just a little different throttle response than usual.
    Should I change oil and filter to be safe or should I just add a quart? If I have an extra quart in can it hurt the motor? My OLM says 75%, so I hate to dump it.
    I had just had tire work done at a dealership, so im guessing it was loosened by accident while up in the air, kind of confusing. . All my other fluids seem full.. sure wish I could check transmission.
    Any advice appreciated.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,918
    Re: oil leaked.. change or add?
    An 18" oil spot is likely about 1 tablespoon of oil. Go by the dipstick.
    Been fixin' cars for 74 years
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by jgodfrey82
    Just to clarify, to check the oil - Engine off, remove dipstick, wipe it off, reinsert, remove, check level. Is that how you're doing it?
    At 3K, there's no reason to change the oil. Follow your OLM. Check the level, add if necessary.
    Jul 2011
    71
    I was checking with engine running, will let it drain down and check again today.
    Sep 2010
    East Boston MA.
    29
    26,323
    Yeah, that was your problem.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    No reason to dump it that I can think of.
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    335
    I'd be more curious as to why my oil filter was loose.
    Ranger007 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX 3.6
    Apr 2010
    Oklahoma City
    86
    Sheepish said
    "I'd be more curious as to why my oil filter was loose."
    Me, too! But...............things happen. I'd be glad I found it in time and that I found it at my house.
    Bill
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    It happens...
    Dealership changed my oil not so long ago!
    Here is a photo of my puddle!
    http://www.mediafire.com/convkey/411...v09yn474fg.jpg
    http://www.mediafire.com/view/n06aec...474/SRXOIL.jpg
    Filter was crooked!
    New filter - - problem fixed.
    Jul 2011
    71
    I change my own oil, so maybe I just didnt put it too tight and it loosened itself over the last 3k miles .. I had tire work done last week, but unless it was just accident, I cant see them messing with it.
    Anyways thanks for the responses everyone... anyone ever had their low oil pressure light come on? If I was down a qt or two would it?
    Apr 2010
    Oklahoma City
    86
    Guarantee you that the oil pressure light would not come on with the 3.6 if it's a couple of quarts (or maybe even more) low.
    Don't know about the Northstar.
    Bill
    Sep 2010
    East Boston MA.
    29
    26,323
    The oil pressure light won't come on until the oil is low enough to starve the oil pump. The low oil LEVEL message will come on at 2 quarts low (~5.5 quarts remaining), nowhere near close enough to trigger the low pressure message.
    Jul 2011
    71
    Thanks for the clarification.
    Professor wizard - my picture would be almost identical, smaller oil spot, same color and sport srx
  16. #14
    Sep 2007
    2,621
    I think the oil level sensor was dependent on the year, I think and cant remember so keep checking especially you V6 guys because the car is not going to tell you.
  17. Remove Advertisements
