2004 SRX Rack and Pinion sloop
Results 1 to 5 of 5
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2004 SRX Rack and Pinion sloop in Cadillac SRX / XT5 Forums; I have movement on my Rack and Pinion shaft it moves in and out about a 1/2 inch, does anyone ...
    georgewerr is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    40
    I have movement on my Rack and Pinion shaft it moves in and out about a 1/2 inch, does anyone know if there is anything that can be
    or is this a total replacement. it is not the tie rod.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,799
    Re: 2004 SRX Rack and Pinion sloop
    I remember seeing a YouTube on replacing the inner rod ends on a R&P setup. Look for that.
    Been fixin' cars for 74 years
    Jun 2008
    40
    Quote Originally Posted by glake89 View Post
    Thank you for the post - but it is not the Tie rod but the Rack itself that has the play. I have not seen this before. I have replaced tie rods before and I'm sure this is not my problem.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,799
    There are inner joints that wear. You can't see them (under the dust boots).
    Jun 2008
    40
    Sorry, I did not know there was any tie rods under the boot. I will check that out[COLOR="Silver"]
    I see on rock auto they sell Raybesto and Moog inner tie rods, does anyone know which company makes better parts, Raybesto's are $15 more per piece and im ok with spending the money if there better but I have never heard anything good or bad with either company and thought I would ask others if they know which is better.
    I plan on replacing both the inners and the outters so I have the same quistion for the outters but also they list the AC Delco also
    Thanks for everyones help
  8. Remove Advertisements
