2008 SRX Coolant Leak while in Park
Results 1 to 14 of 14
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2008 SRX Coolant Leak while in Park in Cadillac SRX / XT5 Forums; I'm the proud owner of an 08 SRX v-6 AWD. As of recent, i have noticed a smell of DexCool ...
    BKSRX4's Avatar
    BKSRX4 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX AWD V-6 Performance Pkg.
    Apr 2013
    Lower Burrell, PA
    43
    6
    Question2008 SRX Coolant Leak while in Park
    I'm the proud owner of an 08 SRX v-6 AWD. As of recent, i have noticed a smell of DexCool while the vehicle is in Park. I, on both occasions, opened the hood and see the Resevoir bubbling, but yet, my temp guage stays the same. There is also a puddle of Dexcool that had been leaking from underneath (more towards the front of the vehicle). I took it (after the first mishap with it in August) to the Cad Dealership (which my SRX is still under the Cert. Pre-owned warranty) and they kept it for five days. They found nothing. At this point, Im thinking I'm losing my marbles. Anyway, about a month later, it happens again. So, now, i dont wana look like the @$$ and call another Cad Dealership and tell them what is happening before I get some feedback. I looked at all the hoses and reservoir and found no leaks in those areas. I'm at a loss, and don't know what else to do. I only have 60k miles on this, and don't think a Cad should be doing this at such low miles...but then again... I could be wrong, just as the first dealership proved me to be. Any help would be greatly appreciated.
    Thanks.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: 2008 SRX Coolant Leak while in Park
    Quote Originally Posted by BKSRX4 View Post
    Thanks.
    Hello BKSRX4,
    I know you are looking for advice from other forum members, but if you choose to work with a new dealership, please let me know. I would like to assist during that process. I can be contacted via private message and would like for you to send me your contact information, VIN and current mileage.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    BKSRX4's Avatar
    Apr 2013
    Lower Burrell, PA
    43
    6
    Laura, please email me at psualumni07@gmail.com, and I will provide you with that information. Thank you so much.
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    61
    1,096
    I am thinking your heater core is about to pop.
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Where is the leak hitting the ground front rear or sides? Check the water pump up front for leaks even small.
    BKSRX4's Avatar
    Apr 2013
    Lower Burrell, PA
    43
    6
    the leak is closer to the front of the engine, more towards the radiator fan, but the leak appears to be closer to the bottom of the engine. I can see the coolant on the frame it self under the engine, but can't pinpoint where it is. Like I said before, it doesnt happen often, but when it does I watch that temp guage.
    Oct 2012
    975
    Closer to the engine or radiator?
    Mar 2010
    Detroit, USA
    12,674
    Hello BKSRX4,
    You are welcome! I wanted to let you know I emailed you at the provided address.
    Sincerely,
    Laura M.
    BKSRX4's Avatar
    Apr 2013
    Lower Burrell, PA
    43
    6
    Closer to the Engine.
    And Laura, I replied via email.
    Thank you
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,798
    Dat wear de waterpump be.
    Been fixin' cars for 74 years
    Mar 2010
    Detroit, USA
    12,674
    Thank you
    You are welcome, BKSRX4. Thanks for letting me know.
    Laura M.
    BKSRX4's Avatar
    Apr 2013
    Lower Burrell, PA
    43
    6
    This is from a friend: Not familiar with Caddys, but there's a couple things that it could be. Your transmission should run through your radiator for cooling. If the transmission is overheating, that could cause
    a leak (pressure build up in the coolant), and you might not get any indication on your temp gauge. Or it could be a bad seal on the transmission cooler itself. Just a thought. I'm definitely not a professional!
    I'm not sure if the AC plays into it, but it could be that it was just hot outside. The added stress of the hot day, plus whatever is raising the temp of the coolant will raise the pressure causing the leak. I'd make sure they do a pressure test on your cooling system, and at least check the color of your transmission fluid. If you have an issue, there's a good chance your transmission fluid will be black.
    The vehicle is at the dealership. Just gotta wait and see if they find anything.....
    Oct 2012
    975
    Don't these trucks have a separate tranny cooler not attached to the radiator so no mixing like traditional cars.
  16. #14
    BKSRX4's Avatar
    Apr 2013
    Lower Burrell, PA
    43
    6
    I have no clue. I am hoping this dealership finds something.
  17. Remove Advertisements
