What oil cartridge do you use?
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By silversport
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, What oil cartridge do you use? in Cadillac SRX / XT5 Forums; I have a 2008 v6 srx... I googled comparisons and found that mobile 1 is way over priced, oem ac ...
    amcon's Avatar
    amcon is offline Cadillac Owners Member
    Automobile(s): 2008 SRX, AWD V6. Esclade 2005 AWD NS
    May 2013
    45
    47
    I googled comparisons and found that mobile 1 is way over priced, oem ac delco seems to have average to poor ratings.
    however the K&N filter seemed a good ballance with price and performance.
    any thoughts?
    anyone change the filter at lets say 3000 miles, not change the oil. then, do a oil and filter change at 6000 miles?
    thanks guys!
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    781
    Re: What oil cartridge do you use?
    I have not changed the oil yet on my new to me SRX But on other cars I have found a good quality oil filter combined with quality oil is the way to go...
    I like Mobil 1 for a lot of reasons and I am not sure I believe it is the best out there but I don't really believe the wild claims of several other oil makes either...that said...I find synthetic better than conventional oil and I've never understood the blends as they seem to contain the worst of both conventional and synthetic...
    Filters used without incident by me on a C5 Corvette, new GTO, Escalade, Avalanche and Mazda6 have been Mobil 1, K&N and Delco Gold (no longer made but their version of a premium filter)...there are others but I think I'm going to buy K&N cartridges unless I read different...using a premium filter (usually with a synthetic filter element over paper) should negate any reason for you to change your filter before changing your oil (IMO)...
    Good luck with your choice...
    Bill
    amcon likes this.
    Pinhauler is offline Cadillac Owners Fanatic
    Automobile(s): 06 v6 SRX
    Sep 2009
    Troy / Mi.
    64
    335
    I use AC Delco = can't be that bad but should be less than $5. when all you get is a paper element and 2-rubber grommets !
    Whiplash_89's Avatar
    Whiplash_89 is offline Cadillac Owners Fanatic
    Automobile(s): 04 SRX V8 AWD, 04 NSRT4
    Nov 2012
    Windsor, ON
    223
    I've never had any issues with oil with any of my cars with the cheapest oil/filter I can find. As long as its changed on time I don't think you will run into any issues.
    dredd2099 is offline Cadillac Owners Member
    Automobile(s): 06 srx
    Oct 2011
    88
    alternate between K&N and Wix
    wix has the o ring included, K&N doesnt
    amcon's Avatar
    May 2013
    45
    47
    Quote Originally Posted by Pinhauler View Post
    ac delco was 12 bucks, and seems they have changed the core of the filter to a whimpy plastic type (not my thoughts but other reviews) and the K&N filter has a Metal type core (says it stays stronger and wont "colapse") cost was 7 bucks.
    i went with K&N
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,000
    Yes, I use AC Delco filters as well. It is difficult to get other makes here. I use mobil1 oil and replace the filter every second oil change. Also, I follow the oil life monitor to determine when a change is needed.
    georgewerr is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    40
    The only choises I have localy is AC Delco and Fram, I had two Frams collaps on me. No problems wirh the AC Delco
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    I use Wix because I can get them easily.
    The Wrench is offline Cadillac Owners Enthusiast
    Automobile(s): '08 SRX V6
    Oct 2007
    Dallas
    542
    Never had an oil-quality or filter-quality-related failure in the last 50 years, including the old Benz in the garage with 240k miles. Don't even know anyone who took reasonable care of their engine who's had one.
    Lots of good oils and filters out there. Buy what you think is a decent one, check the level occasionally, and change it hot and often.
    DG
    ktr-sb is offline Cadillac Owners Fanatic
    Automobile(s): 06 SRX 3.6L 2WD
    Mar 2004
    427
    "Do not use a plastic core filter in the LY7. The filter spins in the housing, and plastic core filters have been known to come apart in these engines. When pulled out, they look collapsed, but really they are twisted apart."
    That's what I used to think, and it may be true based on what I have seen. But I have recently pulled a Fram Tough Guard out of an Oldsmobile engine using the same cartridge-style setup, and it was clearly collapsed by a underperforming core that could not withstand an overly fine filter media overloaded by an extended OCI.
    Nov 2007
    ChicagoLand, USA
    781
    The Delco I just bought had metal ends and mesh inside the cartridge...i have seen at three different Delco cartridges and two had the plastic ends if the pics were correct...the one I picked up at Farm & Fleet was a USA made, metal ended and internally supported filter cartridge...
    Bill
  15. Remove Advertisements
