octane boost - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Like Tree2Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, octane boost in Cadillac SRX / XT5 Forums; really cool info i have learned alot from all your guys input! awesome feed back guys! (i still get better ...
  1. #31
    amcon's Avatar
    amcon is offline Cadillac Owners Member
    Automobile(s): 2008 SRX, AWD V6. Esclade 2005 AWD NS
    May 2013
    46
    47
    Re: octane boost
    (i still get better performance with higher octane...lol)
  2. #32
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Re: octane boost
    Quote Originally Posted by silversport View Post
    right...we have a variable valve timing version...
    Bill
    DI is how the fuel is delivered tot he motor, valve timing is well valve timing, I don't get the connection.
  3. #33
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    829
    Re: octane boost
    Quote Originally Posted by conedoctor View Post
    I should have hit the quote and was responding to SC2150's response to mine about Direct Injection...but I was pointing out that our V6 in the SRX is not the newer Direct Injection motor but the older VVT 3.6...
    Bill
  5. #34
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    Re: octane boost
    Yes. With the LY7, using any octane above the CR of the engine needs is a waste for sure.
  6. #35
    amcon's Avatar
    May 2013
    46
    47
    Re: octane boost
    This suggests that either the 3.6 motor with vvt is engineered dynamically to utilize higher octane fuels or the idea of octane can't be easily explained as it was above.
    "if your vehicle has the 3.6L engine (vin code 7), use regular unleaded gasoline with a posted octane rating of 87 or higher. For best performance or trailer towing, you could choose to use middle grade 89 octane unleaded gasoline. If the octane rating is less then 87, you might notice an audible knocking noise when your drive, commonly referred to as spark knock. If this occurs, use a gasoline rated 87 or higher as soon as possible. If you are using gasoline rated 87 octane or higher and you hear heavy knocking, the engine needs service.
    If your vehicle has the 4.6L v8 engine (vin code A), use premium unleaded gasoline with a posted octane rating of 91 or higher. You can use regular unleaded gasoline rated 87 or higher, but your vehicle's acceleration could be slightly reduced, and you might notice a slight knocking noise, commonly referred to as spark knock. if the octane is less than 87, you might notice a heavy knocking noise when you drive. if this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you could damage the engine. and if you hear heavy knocking, the engine needs service.
    Use of the recommended fuel is an important part of the proper maintenance of your vehicle. To help keep the engine clean and maintain optimum vehicle performance, we recommend the use of gasoline advertised as TOP TIER detergent gasoline.
    Additives - bla bla cleaner air... additives that help prevent engine and fuel system deposits from forming, allowing the emissions control system to work properly. In most cases, you should not have to add anything to the fuel. However, some gasoline contain only the minimum amount of additive required to meet US environmental protection agency regulations. To help keep fuel injectors and intake valves clean, or if your vehicle experiences problems due to dirty injectors or valves, look for gasoline that is advertised as TOP TIER Detergent Gasoline. Also, your dealer/retailer has additives that will help correct any prevent most dpeooit-related problems.
    taken from the owners book 5-5 through 5-7.
  7. #36
    Nov 2007
    ChicagoLand, USA
    829
    Re: octane boost
    ...or that trailer towing puts more load on the engine than you would driving without towing and that perhaps 89 octane would help...or it's just rubbish...still...as it relates to the V6, using higher than normal or perhaps 89 when towing is a waste of money...
    Bill
  8. #37
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: octane boost
    Well I thought it was bad gas that I got, however last night the car started sputtering again and threw a misfire into cylinder 2 (last time it was 3). Went and put 93 octane in (it had a half tank of 87) and after going home shutting it off and starting it up it was running okay. This morning it ran fine most of hte way into work then started sputtering again as I parked it at work.
    Any idears?
  9. #38
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    Re: octane boost
    Again, top tier fuels (as in the diagrams showing fuel introduction between conventional port injection and direct injection. Top tier fuels are very important with traditional port injection where the fuel is coming through the injector at 45-55 PSI VS 2-3000 PSI w/DI where deposits get no chance to form, and the fuel with DI never touches the intake valves so it can have no effect.)
    Your owners manual is quoting a older port injection where you DO need top tier fuels
  10. #39
    Nov 2007
    ChicagoLand, USA
    829
    Re: octane boost
    does anyone here have a DI engine???...Top Tier is more than the cleaning agent additives...
    Bill
  11. #40
    Sep 2007
    2,621
    Re: octane boost
    I do but in my CTS, the SRX is not DI and I don't know why it keeps being brought up as people are getting confused.
  12. #41
    Nov 2007
    ChicagoLand, USA
    829
    Re: octane boost
    thank you...that's my point...it confuses the issue in this thread...interesting information nonetheless but...
    Bill
  13. Remove Advertisements
