Driver's side parking light and turn signal
Results 1 to 7 of 7
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Driver's side parking light and turn signal in Cadillac SRX / XT5 Forums; Driver's side parking light (orange) doesn't come on, and turn signal blinks twice as fast as the passenger side. replaced ...
    ojlove is offline Cadillac Owners Member
    Automobile(s): 2008 CTS, 2004 SRX
    May 2013
    9
    Driver's side parking light (orange) doesn't come on, and turn signal blinks twice as fast as the passenger side. replaced the bulb and still nothing. Really don't want to pay the dealership to fix such a seemingly simple problem.
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: Driver's side parking light and turn signal
    If you do a search on this forum you will find a lot of info on this, includind a DIY approach to front end bulb replacement without taking off the front fascia/bumper. All it takes is a torx wrench, and you go at it by removing the wheel and peeling back the inner fender well. Your problem may very well be a bad bulb socket. Common.
    mjcaddy's Avatar
    mjcaddy is offline Cadillac Owners Fanatic
    Automobile(s): 09 1SG STS4 & Subie CrossTrek (retired 03 DeVille & 05 V6 SRX4)
    Oct 2010
    Chicagoland
    33
    428
    (check the simple things first, did you check if there are any corrosion on the harness/bulb housing or any burning marks ?
    that happened to my car before, you'll just need to clean it good and make sure the bulb sits snug there.
    May 2013
    9
    ok, I can check that this evening after work.
    ok, I can check that this evening after work. its a big hassle trying to get under there with having to take the wheel off and everything else associated with just changing that one bulb.
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    The socket is bad.
    Linkinyeah is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX ALL WD V8
    Aug 2013
    31
    How do you find out the part number for the socket on a 2005 Cadillac srx? Also, how did you know it was the socket?
    Jun 2012
    51
    326
    The bulbs are dual filament. The odds of both burning out at the same time isn't likely. What happens is that the socket overheats (this is a known problem with these vehicles) and the bulb stops working completely. I just had to have my dealer replace mine.
  10. Remove Advertisements
