oil leak on my 2004 SRX
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By n7don_srx
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, oil leak on my 2004 SRX in Cadillac SRX / XT5 Forums; We changed the oil on our 04 srx 3.6 awd. I put in a new oil drain plug thinking the ...
    geiss1225's Avatar
    geiss1225 is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Awd 3.6 srx
    Jul 2013
    Phoenix AZ
    56
    3
    We changed the oil on our 04 srx 3.6 awd. I put in a new oil drain plug thinking the rubber seal
    Was bad, but I am still getting drips in drive way. The car has 80,150 miles on it. Can anyone
    Please advise me where to look ? The car runs excellent, the only other issue I have had the
    exhaust pipes rattles a bit when the car starts.
    Thank you
    Jim G
    orandaberg Guest
    Anyway to get the truck lifted and look underneath. If you have the splash shield you will need to remove that. If your lucky its just could be a loose oil filter or pan gasket. If its the drain plug you may have over tighten the plug(forgot o-ring). I read the 3.6 uses a lot of oil? Maybe all the fill ups with oil have spilt down an accumulated on the shield and is finally dripping.
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    792
    Re: oil leak on my 2004 SRX
    First I hate oil leaks that make it to the ground!
    I'd think if the leak were at the drain plug it would be very noticeable.
    Are you sure it's engine oil? Being an AWD the front differential could be a leak source, especially the axle seals. An inspection from the bottom, as recommended by orandaberg would be your best bet. You may get a clue by observing the leak's location on the driveway/garage floor in relationship to where it occurs HOWEVER leaks are like a roof leak. Often it runs from one location to another before it hits the ground.
    BTW, item 712 in the graphic was discontinued and you probably don't have it. It's an oil level monitor sensor.
    geiss1225 likes this.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    You have the other oil level monitor, make sure you know how to use it
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Quote Originally Posted by conedoctor View Post
    Now you know the updated device is much harder to operate than waiting for the warning light hahahahhaha
  8. Remove Advertisements
