SRX Power seat stopped working
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, SRX Power seat stopped working in Cadillac SRX / XT5 Forums; The driver's power seat on my 2008 SRX stopped working. If I press up/down, forward/reverse or the lumbar switches the ...
    Richj is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX
    Mar 2007
    Sparta, NJ
    16
    The driver's power seat on my 2008 SRX stopped working. If I press up/down, forward/reverse or the lumbar switches the seat will move about an 1/8 of an inch and stop. I think I hear a click as the seat stops moving. It sounds like the circuit breaker is tripping. If I wait 5 or 10 seconds, it will do the same thing. The passenger seat works fine.
    I checked the wiring under the seat and everything looks fine.
    What should I check next?
    Rich
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,666
    Re: SRX Power seat stopped working
    Quote Originally Posted by Richj View Post
    Rich
    Hello Richj,
    I am sorry to hear that you are experiencing an issue with your SRX’s power seat. I see that you are looking for advice from the community in regards to addressing the concern yourself. If you do plan on taking your vehicle to the dealership if you are unable to address the situation, please feel free to private message me and I would be more than happy to assist you in working with the dealership. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    It very well could be a circuit breaker. Find the location in the fuse box for the drivers seat and see if it is one. If so, then it may be bad. Maybe switch it with a different one that is in the box (the passenger side?).
    orandaberg Guest
    Jun 2012
    51
    326
    Yep, a 30a breaker located in the right rear fuse panel. I would replace that first and see. If it is indeed tripping due to an overload then there may be something binding and causing too much load on the circuit.
    Mar 2007
    Sparta, NJ
    16
    I ran another test. I had my wife push the passenger seat switch forward while I pushed the driver seat switch. Her seat did not stop. Since there is only one fuse that feeds both seats, the fuse does not seem to be the problem.
    Could the power seat module cause symptoms like this?
    Jun 2012
    51
    326
    Good thinking. No, I don't believe that the module would cause this. So I am clear, is it only the seat motors that are not working or is it any of the seat functions too, like the lumbar?
    Mar 2007
    Sparta, NJ
    16
    All of the functions do the same thing. Up/down, forward/back, lumbar in/out, front of seat up/down. Push any of these switches and the seat will jog about 1/8" and then stops. Wait a few seconds, try again and it moves another 1/8".
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,787
    Problem could be in module, get a reading for DTCs, there's a bunch for seat malfunctions.
    Been fixin' cars for 74 years
    Jun 2012
    51
    326
    So pushing the lumbar moves the seat too? Ok, that may indeed be the module. You need to find someone with a Tech 2 (I have one) and do some diagnostics on whatever module controls the seat.
    orandaberg Guest
    Quote Originally Posted by rlh6805 View Post
    I think he meant all the functions only move a 1/8" and stop?
    Mar 2007
    Sparta, NJ
    16
    Each time you press any of the seat switches, the seat will move the direction you push it but only about 1/8 of an inch.
    Pushing any switch only moves the seat in that path either up/down forward/back etc.
    You can walk the seat in any direction but you have to wait about 5 seconds after each push and then push it again.
    Is there a way to get codes on the information center like there was on my 93 Eldo or do I have to get a scanner?
    BTW, I tried pushing the memory seat switch and it moves the seat in 1/8 " increments to like it is trying to get the seat into the memory position.
    orandaberg Guest
    My guess is you need DTC, probably a bad seat module
  16. #14
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,787
    Richj, most chain parts stores will read codes for you, NC.
  17. #15
    Mar 2007
    Sparta, NJ
    16
    It was the set module. I replaced it and the seats work fine. However, the heated seats don't work correctly. The driver seat bottom warms up, the back does not. It turns off after few minutes. The passenger seat heater switch lights up for about 1 minute then shuts off. The passenger seat does not heat up.
    I checked all of the connections and they seem ok.
    Does the module need to be programmed by the dealer?
  18. Remove Advertisements
