brake parts
Results 1 to 12 of 12
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, brake parts in Cadillac SRX / XT5 Forums; I have a 2004 SRX AWD and I'm leaking brake fluid in the rear there is a part that the ...
    040777chris is offline Cadillac Owners Member
    Automobile(s): 2004 srx awd
    Sep 2013
    40
    11
    brake parts
    I have a 2004 SRX AWD and I'm leaking brake fluid in the rear there is a part that the brake lines go in to from the front then leave this part and go to the rear end does anyone know what this part is called it is located just in front of the rear passenger tire
    orandaberg Guest
    Re: brake parts
    Which number on here, there is nothing just in front of the rear tire, the side yes, the only area in front of the rear passenger side is where ithe brake lines bend in the frame, this area also has the fuel filter
    Sep 2013
    40
    11
    Re: brake parts
    Thanks that makes a lot of since it looked like a fuel filter to me and the fluid was leaking from the top of it I must have a broken line above the filter Is there a way to coupling a broken line without having to replace the whole line
    orandaberg Guest
    Re: brake parts
    could be #8 leaking, you need to get under and look either with a crawler if you have drive up ramps or lift the truck
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    If that quick connect is damaged you can replace it with a section of fuel grade hose wig pressure clamps and be fine. I've done that on several vehicles especially with the brittle PLASTIC fuel lines on the 3.8 motors
    Sep 2013
    40
    11
    Re: brake parts
    Its the brake line is leaking. Is the brake line
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,918
    Re: brake parts
    You can splice a new section of brake line if you have and can use a flaring tool.
    Been fixin' cars for 74 years
    orandaberg Guest
    Re: brake parts
    Do not know where you are from 040777chris , if its Europe, in most countries, its illegal to splice brake lines, it will work but would not pass the EU control and if insurance found out you would loose coverage in a accident.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Re: brake parts
    I agree it can be repaired and I agree with Rusty troll, may not be a good idea.
    Maybe just a connection?
    orandaberg Guest
    Re: brake parts
    Now I have to change my signature to Rusty Troll?
    Sep 2007
    2,621
    Re: brake parts
    As you should...
    orandaberg Guest
    Re: brake parts
    Quote Originally Posted by glake89 View Post
    Flaring tools are not ABC,buy a cheap one and you end up doing the job a couple times, I know I have been there, I just ended up removing the whole line and replacing it. If your DIY you can do it yourself(removing) and take it to a shop to copy it and let them flare it for you. I am sure in the states you have tons of shops to replace brake lines, is the truck drivable?
  15. Remove Advertisements
