Results 1 to 7 of 7
Thread: Persistent steering wheel shimmy
    jackw3306 is offline Cadillac Owners Member
    Automobile(s): SRX
    Jul 2012
    68
    1
    2008 SRX V6 RWD. Bought the car 12/2010 with 22K miles. Had a shimmy in the steering wheel. Replaced 4 tires, went away for about 1000 miles while but returned. Has done the same with 3 sets of tires. Rebalancing helps for a while (500-1000 miles) but problem returns. Starts at about 60 MPH goes away about 75.
    Any help appreciated.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,921
    Re: Persistent steering wheel shimmy
    Alignment; rotor runout; wheel runout/balance; try on-car balance; check for loose rack, worn ends.
    Been fixin' cars for 74 years
    orandaberg Guest
    Are they aftermarket wheels? From past experience it may be a balance issue, when they put the counter weights on, they may come off or they may have not put them in the "sweet spot", some use the sticky tape weights, some use the clip on weights
  5. #4
    jgodfrey82 is offline Cadillac Owners Member
    Automobile(s): 07 SRX NorthStar - just purchased, and loving it!
    Jul 2011
    71
    Jack - I have had the same issue with my 07 v8 rwd. It started after I put 4 new continental tires on back in May 2012, stock 18 inch wheels. Cadillac never could fix it with their balance machine. Warrantied 2 tires, came back again, continental agreed to warranty another 2, but I never got them.
    After weeks of back and forth calls with my service writer, he eventually blew me off, never returning my calls and giving me the run around when I called. I just decided to go to a brand new Chevy dealership in town and they immediately said road force balance. It feels a lot better, though not 100%. Its probably only been 3 weeks and 1000 miles, so time will tell if it comes back. One thing is for sure, massey cadillac lost any service business from me.
    Honestly I just think the srx is very picky with tires, any out of round is intensified. My next set will definitely be michelans.
  6. #5
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    830
    you mention twice in your response about tires being the culprit...either out of round or something that requires a warranty...how is that the fault of the SRX...out of round tires are a tire manufacturing issue...I had this issue with my Escalade and it was a Bridgestone tire that once removed from the equation, the issue went away...hopefully the OP gets his issue fixed...
    Bill
  7. #6
    Mar 2010
    Detroit, USA
    12,711
    Quote Originally Posted by jgodfrey82 View Post
    Hello jgodfrey82,
    I am sorry for any trouble you had to experience while fixing your vehicle. I am glad you were able to work with another dealership which helped work towards a resolution for you. I see your vehicle feels better than before, and you are going to continue to monitor it as its only been a few weeks. Please don't hesitate to reach out to us if concerns or questions arise. We are here to help!
    Sincerely,
    Laura M.
    Cadillac Customer Care
  8. #7
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    jgodfrey has it right. Tires with minimal runout and an in spec Hunter force balancer usually do the trick if the alignment is in spec and the suspension is up to snuff. Round tires are NOT a given, and tire manufacturer tolerances very. PJ
  • You may not post replies
