3rd row seat will not go up
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 3rd row seat will not go up in Cadillac SRX / XT5 Forums; Hi The third row seat will not go up after pushing the unlock button 3x either at door or key ...
    orandaberg Guest
    Hi
    The third row seat will not go up after pushing the unlock button 3x either at door or key fob, the is 3 bells when I press the seat position button on the rear cargo trim, but nothing happens, no motor sound as before in rear
    Now the cargo door will not open, manually or with keyfob
    orandaberg Guest
    Re: 3rd row seat will not go up
    Had to start the truck to open rear lift gate, lift gate works as it should now, looked at all the fuses in rear passenger(left hand side fuse 10 amp)no DTC
    Now my air bag light is on and service air bag on DIC
    Could all the modules need relearning after being out of power for so long. have not used the truck since taking the battery out and during battery problems before, so in all maybe 3 weeks since I drove it longer then 10 mins.
    The manual states The vehicle cannot have a low battery. I currently am charging the new battery to its full charge, it has not reached full charge yet, it flashing on 3/4 full charge, been that way for about an hr so I will let it charge till tomorrow afternoon. But it should still work at 3/4 charge?
    orandaberg Guest
    Sorted out the air bag on light the fuse SIR was put into the spare whole next to it when I checked,so that's sorted, battery fully charged but pressing the key fob 3x and pressing the seat switch rings chimes up front (same sound as if you did not press the key fob 3x.
    fuses in green OK
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,798
    Here's where to look-
    Power, Ground, Serial Data and Controls (AM0)
    Been fixin' cars for 74 years
    orandaberg Guest
    Thanks
    That went way over my head, can you be a bit more step 1 step 2 type explanation?
    OK here it is. Is there a stow switch front?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Sometimes I had to mess with the button in the back area and hold them longer than usual.
    orandaberg Guest
    Yeah tried that first of 2 buttons forward make the chimes ring, second button rear does nothing
    xboxman72 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX4 V8 Sport Package
    Aug 2012
    44
    56
    Mine does the 3 chime thing when the plastic tab is not in the slot all the way after flipping the carpeted panel up. Maybe the safety switch is sticking?
    orandaberg Guest
    Thanks I will try it some more tomorrow, but I did try wiggling it around and pressing, have to look with a light to see if there is something to press, but I would of thought that if there was a safety switch it would show in the schematics
    Oct 2012
    975
    Damn I forget yeah that carpet panel has to be pulled out already slaps forehead totally forgot that's what worked on mine
    orandaberg Guest
    I really do not think there is any safety switch in there. I think its just to hold the flap in place
    the folding seat may be in an unknown state and out of calibration with the RSM. Therefore, the RSM must be calibrated before the folding seat system will operate. Refer to Power Folding Seat Calibration . To do this requires the stealer, I think they have to look for DTC on this. UFFF they will have no clue here what to look for, or even know how to use the calibration, I may have to print out how to. problem is its my dime while they scratch their ass, and at over 200 dollars an hr!!!!results or not!
    Just when I thought I got the parasitic draw figured out and sell with torn suspension air bags,now I have to sell with non functional 3 row, gets better and better
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    36
    144
    Before folding or unfolding the third row seat, all of the
    following conditions must be met:
    • The liftgate or passenger’s side rear door must
    be open.
    • The unlock button on either the remote keyless entry
    transmitter or the door must be pressed three times
    to enable the rear seat for two minutes, or the ignition
    must be in ON/RUN or ACC/ACCESSORY.
    • The vehicle must be in PARK (P).
    • The vehicle cannot have a low battery.
    After the seat is folded, fold the panel on the seat
    forward flat on the floor.
    If the seat’s path is blocked it will stop and back away.
    Press the button again to return the seat to its previous
    position.
    Before returning the third row seat to the passenger
    seating position, the panel must be folded back upon
    itself. Press and hold one of the power folding seat
    buttons and the seat will unfold into the seating position.
    If the seat is not unfolded fully into the seating position,
    a chime will sound when the vehicle is shifted out of
    PARK (P). This indicates that the seat is not ready
    for a passenger.
    low battery voltage perhaps? or the vehicle isn't recognizing the open hatch or rear passenger door?
    orandaberg Guest
    Well I get a lift gate open on my DIC, for some reason its not recognizing the 3x unlock, I can hear the locks open 3x. Battery is new and fully charged. If it was not recognizing the gate open, I would not get the chimes when pressing the unfold button, if the gate is closed the buttons are inoperative, no chimes, no function, the same goes for if its in drive.
  16. #14
    orandaberg Guest
    Surely someone out there has run into this an had it fixed
  17. #15
    orandaberg Guest
    For those who think there is a safety switch in the folding latch (there is none)
    http://www.justanswer.com/cadillac/4...t-go-back.html
  18. Remove Advertisements
