Rattle engine noise under acceleration
Results 1 to 15 of 15
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Rattle engine noise under acceleration in Cadillac SRX / XT5 Forums; My engine makes a rattling sound under acceleration, it does it everytime a depress the gas pedal. Like I'm driving ...
    desmar's Avatar
    desmar is offline Cadillac Owners Member
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Like I'm driving a manual transmission that is in a higher gear instead of a lower gear, example tranny is in 5th but should be in 3rd, then it makes a rattling noise.
    My srx does it for several seconds everytime I'm accelerating from a stop, coasting & I accelerate, etc.
    Any ideas, other than this it drives greAT, fuel is good, 12.6 liters/100 kms, new plugs, fuel filter change, injectors & intake manifold cleaned & flushed.
    D.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Re: Rattle engine noise under acceleration
    Quote Originally Posted by desmar View Post
    D.
    Hello desmar,
    I apologize that that you are experiencing a rattling sound when you are accelerating. I do see that you are located in Canada. Have you reached out to the Customer Care team in Canada regarding this issue? Their number is 1-888-446-2000. Please keep us updated on the status of this situation. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    If it sounds like a case of empty Coke bottles (shows how old I am), it's pre-ignition. I'd check out the KSs (knock sensors).
    Been fixin' cars for 74 years
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Glake89, thanks for your idea.
    Tried antiknocking additives, higher octane gas, even change plugs thinking one could've been bad.
    orandaberg Guest
    None of that would have worked if your KS were faulty
    xboxman72 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX4 V8 Sport Package
    Aug 2012
    45
    56
    Loose heat shield on the exhaust pipe by the transmission?
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    Quote Originally Posted by xboxman72 View Post
    Yes, there is a TSB about that. It was the first thing I had the dealer fix when I got mine. It just needs to be welded back up.
    Aug 2012
    45
    56
    fixed mine with a hose clamp
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Benn there, removed the shield above the cross pipes resonator, around all cats, spare tire, even applied rubberized under carriage coating. But no luck.
    Like I mention it sounds like a baby rattle or you are driving uphill with a manual tranny in a higher gear that what you are supposed to be in. Ex drive uphill in second but you select fourth instead give gas ang engine rattles, or knocks or detonated whatever,
    Gas mileage is being affected now & engine doesn't iddle as smith as before it kind of misfired every few seconds, Roma will go up & down for a few hundreds.
    So it's not chassis related or loose car parts is engine or drivetrain related, maybe transfer case chain??!!
    tasbro is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    28
    My '06 3.6L had a rattling type noise upon acceleration. It's presently in the shop getting new catalytic converters.
    Mar 2010
    Detroit, USA
    12,687
    Quote Originally Posted by tasbro View Post
    Hello tasbro,
    I am sorry to hear about your current situation you are dealing with due to the rattling issue upon acceleration with your vehicle. I see your vehicle is currently getting new catalytic converters. If there is anything we can do to help; answer additional questions or concerns, don't hesitate to reach out to us.
    Sincerely,
    Laura M.
    ezcadillac is offline Cadillac Owners Member
    Nov 2014
    27
    13
    Tasbro, its rattling because of catalytic ?
    RussellBoulding is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Eldorado Biarritz
    Nov 2014
    St. Petersburg, Fl
    418
    Does it make the noise if you rev in park or neutral or if you "power brake" the car.
  16. #14
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,622
    Timing chains probably, what year SRX? The symptoms sound all too familiar with my girlfriends' SRX- I ended up changing all three chains.
    For more info on timing chains click here:
    http://www.northstarperformance.com/36services.php
  17. #15
    RazorME is offline Cadillac Owners Member
    Automobile(s): CTS or SRX
    Feb 2009
    3
    Check your engine oil level - my SRX rattlings on acceleration or hard braking/cornering when it gets low due to excessive oil consumption.
  18. Remove Advertisements
