Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac SRX Forums > Cadillac SRX First Generation Forum - 2004 - 2009
Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
cadillac-srx
Cadillac Forums: Water in rear jack compartment?
  #151 (permalink)
Old 12-07-08, 04:04 PM
Cadillac(s): 05 SRX~AWD sold 04 CTS V sold 03 CTS Lux/Spt sold
View Cape Cod CTS's Photo Album
Casino Cash: $1590
Re: Water in rear jack compartment?
I believe I found my problem I applied seam sealer around the whole rear hatch opening these panels are only spot welded and some areas where open enough for water to infiltrate into the jack compartment , I'll keep you updated if this was the cure
  #152 (permalink)
Old 12-07-08, 05:38 PM
Cadillac Owners Enthusiast
View john d's Photo Album
Casino Cash: $6215
Same open seams behind tail lights
  #153 (permalink)
Old 12-08-08, 09:49 PM
Cadillac(s): Cadillac
View Wombat2go's Photo Album
Casino Cash: $460
Water is one thing. I just had a practice of changing the spare wheel at 25 F before heading on a trip.
The jack was frozen solid to the floor via the carpet and there is no way it would pry off. Ended up breaking it loose with a large hammer.
These caddies should come with a Jack Hammer!
  #154 (permalink)
Old 12-09-08, 01:09 AM
Cadillac(s): 2005 SRX loaded black beauty
View Jason Fritz's Photo Album
Casino Cash: $300
researched this issue before buying, so thanks for the info.
my compartment was dry, but had them recheck all seals, etc. and havent had issues yet since october. cross my fingers for the future.
can't believe that this isn't a recall yet though with so many documented cases.
good luck guys and gals...
  #155 (permalink)
Old 12-09-08, 10:53 PM
Casino Cash: $1590
Tonight should be a good test.... rain tonight in the BBay
  #156 (permalink)
Old 12-10-08, 08:09 PM
Casino Cash: $1590
Still leaking so I finally got pissed and put the garden hose on the roof and flooded the Shi% OUT OF IT well guys I found where mine is leaking from it's a very simple fix just caulk or seal the ultra roof drain gromment on both sides of the body these gromments do not seal the pentration as tight as the accordian gromment I hope this helps email for pics
Good Luck All
  #157 (permalink)
Old 12-10-08, 11:05 PM
Cadillac(s): 2006 Cadillac SRX
View G32006SRX's Photo Album
Casino Cash: $5065
Good Luck All
I'd like to see the pictues..my dealer was close..he said the drain hose fell off...but it's still wet...
  #158 (permalink)
Old 12-12-08, 01:25 PM
Cadillac(s): SRX
View avantgarde's Photo Album
Casino Cash: $370
what about SRXs without the Ultra View?
It was a horrible 3 days of ran recently and my Jack compartment is slightly moist. I have a feeling in a couple years it'll be unruly. What areas do you suggest other than weatherstriping?
  #159 (permalink)
Old 12-12-08, 03:06 PM
louisn's Avatar
Cadillac(s): 2004 srx V-8 awd
View louisn's Photo Album
Casino Cash: $8821
One of my old posts
"Top brake light--side seals--top seals---moon roof---rear winshield washer--clogged drain holes--covered drain holes--misaligned hatch--misaligned latch......any others????There is no consensus fix from GM as far as I know." And there are more fixes.............since I posted that about a year ago. I've had 5 fixes in 4 years-last one about 2 weeks ago. Still dry, I think..
  #160 (permalink)
Old 12-27-08, 09:10 AM
b4z b4z is offline
Cadillac(s): '07 SRX
View b4z's Photo Album
Casino Cash: $2750
dealer ordered new weatherstripping for my '07 and will get if it fixed next week.
They had 3 model years to fix it since my '04 leaked.
  #161 (permalink)
Old 12-28-08, 11:08 AM
louisn's Avatar
Casino Cash: $8821
I suspect the leak is not discovered often--only if you have a flat or read this forum. I would never have known unless I checked after I read this thread. Therefore, in the real world it's so infrequently reported to the dealer, it's not a big problem to GM. Obviously, since there is no real fix-just band aids and prayers. Now, if 100,000 srx owners complained, they might notice.
  #162 (permalink)
Old 01-10-09, 11:25 PM
View srx05v8's Photo Album
Casino Cash: $1760
There have indeed been A LOT of complaints on this. I think the real challenge is that there could be many different causes for the leak (hence no single reliable fix). Most of the times, it's related to poor sealing (such as worn weather strip); then it could also be a blocked draining system or the rear window washer system. You just need to keep trying. My car had a really bad leak when I bought it. They changed the cracked weather strip and now my jack compartment is so dry it's dusty even during the rain season...
  #163 (permalink)
Old 03-07-09, 11:34 PM
View Tominator's Photo Album
Casino Cash: $300
Originally Posted by krug300 View Post
Have you dealer remove the plastic tailgate sill. Pull up/away the carpet that comes up to the sill (after removing jack, headrest tray if car has 3rd row seats, etc). There is a quarter inch hole in the middle of the inner surface. That's where the water ends up, and down to the area beneath the carpet.
Remove the rear tailgate rubber weatherstrip/seal. You will see that the "outer body" mates to the "inner body" and the weatherstrip fits over this joint which runs around the rear opening of the car. Apply sealant all around this joint and re-install the weatherstrip/seal. New seals come with glue/sealant preapplied. The other (much less) suspicious points are the seals where the tailight screws come through the body. You have to remove the rear trim to check how tight the 4 nuts holding the two tailights are. It took me almost a dozen visits to the dealer to finally locate the suspicious point of water entry (behind the rear door seal).
Krug nailed this one! I removed the complete rear gasket and found a assembly line problem (Take Note GM) The "Beetle Tape" (Black sticky stuff) they use to seal the gasket. Was properly attached to both sides of the metal that the seal is snapped on top of. The problem is someone on the line never removed the "Top" cover that protects the Beetle Tape sticking to things during installation! All I did was carefully removed the clear cover (From both the top and bottom sides) and ran a good bead of Clear silicone for a extra measure then reinstalled the seal. Original one is in perfect shape but as stated in Krug's thread the water is being balsted under the seals mount if you can believe it. Not affected by rain but the power of the water jets at the car wash! I had over two inches of water in my rear compartment. It amazes me how that water got in there...
Thanks for the great info! Dealer was clueless!
Tomas
  #164 (permalink)
Old 03-07-09, 11:39 PM
Cadillac(s): 2006 SRX, 2008 G37 6MT
View Klei14's Photo Album
Casino Cash: $2905
I really need to take a look at mine, I know the car had this problem in the past.
Last time I looked it was dry, but after the next wash I'm going to take another look.
I want to Dynamat the entire area where the jack is,but it wont be possiable if its full of water.
  #165 (permalink)
Old 03-30-09, 12:10 PM
Cadillac(s): 2008 SRX
View TPetersons's Photo Album
Casino Cash: $275
Responding to member asking if anyone has the same issue with an 08-affirmative. I am just getting into this process and will advise progress.
Tags: , , ,
compartment, jack, rear, water
