What DIC displays after dead battery - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, What DIC displays after dead battery in Cadillac SRX / XT5 Forums; Verdit bad battery, have to wait a few days to order a new one. Then I will do the draw ...
  1. #16
    orandaberg Guest
    Re: What DIC displays after dead battery
    Verdit bad battery, have to wait a few days to order a new one. Then I will do the draw test again with a better multimeter and see why this POS is on its 3rd battery in a little over a year. Actually if you count the original one that was in the truck before the dealer changed it this would be #4
  2. #17
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Aren't there warranties for batteries? Also oj the bench doesn't give an accurate reading. I've done ky own tests with a scanner vs the bench. My ram with auxillary cooling fan added on the truck under full load was down to 12.2 and with just the fans and Ac was 12.6. On the bench it was 14.1. New alternator under full load on the truck 13.6. Conclusion benches don't put enough load on them. Let's hit each others srx head on so we can both get out of these lol
  3. #18
    orandaberg Guest
    Quote Originally Posted by repnatl View Post
    I did both, I had access to it when the front end was off replacing the radiator, so may as well try it, if it did not at least pass a bench test I knew I ws good to get a new one while the front end was off, and then a test when everything was back on and it showed charging. Yes the battery is being replaced free
  5. #19
    orandaberg Guest
    When I connect the anp meter in series I get a draw up to 4.11 amps. While holding it in place within a minute it draws down to about 0.38. So I have to assume connecting only wakes up whatever then goes off. So I have no draw on the car if it will not stay high.
    Ok I see 0.38 amps eaual 380 milli amps so its has a draw of 330 mill amps to much if 50 milli amps is the normal acceptable draw. Anyone know the acceptable draw on a Cadillac, I am sure its not the average norm.
    first time hooked up
    After 30 sec and stays there
    After removing radio fuse
    So now I need to find out why my headunit is drawing 250 milli amps (actually 200 minus the 50 milli norn) at rest, any ideas while I goggle it, 175 dollars if I take it to the only car stero installer in town to check.
    Hopefully this was it and I can eat my words!
  6. #20
    orandaberg Guest
    I think I solved it. The F/R camera's power supplies(2) were hooked up to constant yellow 12 volt supply. After moving both to ign on I reconnected the amp meter with radio fuse back in place did the same as before but dropped to 0.05. So hopefully that was it.
  7. #21
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,946
    PP (persistence pays)
    Been fixin' cars for 74 years
  8. Remove Advertisements
