radio
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, radio in Cadillac SRX / XT5 Forums; My radio works but I have no sound..signal light/cd player everything works ...so what could be..my amp or fuse..if so ...
    rocQsolid is offline Cadillac Owners Member
    Aug 2013
    10
    radio
    My radio works but I have no sound..signal light/cd player everything works ...so what could be..my amp or fuse..if so where is fuse...thanks
    orandaberg Guest
    Re: radio
    I read on here touching the positive and negative battery cables together can reset the modules, of course the cables must be disconnected from the battery, this was recommended for another member who had radio power but no sound. The fuse is under the hood for the radio, but if its on its cannot be a fuse. Try a search on this SRX forum, I have seen the question before.
    goodman6986 is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac SRX
    Aug 2013
    5
    Re: radio
    Try the fuse labeled "AMP" It is in the rear fuse box behind the driver seat. If you are sitting in the back seat directly behind the driver seat, the box will be right behind your heels. You have to pull the carpet down to get to it. It will have Velcro so dont worry, you do not have to cut anything.
    Aug 2013
    10
    Quote Originally Posted by goodman6986 View Post
    Ok will try that, I hope thats all it is
    Aug 2013
    5
    Re: radio
    No problem, Let me know if that worked
    Aug 2013
    10
    I check all my fuses and one mechanic said his girl friends father had that problem and it was the control module..so is it one module or a specific name...
    orandaberg Guest
    Re: radio
    Yes thats why I mentioned touching the negative and positive cables together( unattached from the battery!!) this is suppose to reboot modules. If I am wrong please someone correct me, I believed I spoke about this on a thread somewhere
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,878
    Re: radio
    If you have a module not working you will have DTCs. Get to a parts store that will read codes for you, (all 4 types, P,C,B and U)
    Been fixin' cars for 74 years
    Aug 2013
    10
    Ok so im going to touch the cables and see what happens...can an auto part store test or do I need to take it to the dealer.
    orandaberg Guest
    Re: radio
    From what I understand your auto shops can do the test for you, I think they call it autozone?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Quote Originally Posted by orandaberg View Post
    I worked at Autozone they aren't allowed to touch the cables together due to a risk. Trust me I've seen ppl blame everything like the ligh bulb we changed is the reason his transmission is bad or the new radiator he bought going bad was the reason he drove it till the head gasket blew. But Autozone can check the codes but can't delete them.
    orandaberg Guest
    Re: radio
    LOL I meant for him to do the DTC @ autozone not touch cables for him
    Aug 2013
    10
    So I was told it was my control module..is there more than one module..if so which one is the control module..thankss
  16. #14
    orandaberg Guest
    Did you look for DTC? Any way to contact the girlfriends father? Just for grins can you hook up a spare/junk speaker to the head unit an just see if sound comes. What year?
  17. #15
    orandaberg Guest
    Re: radio
    looking in the repair manual I do not see a module that would control sound
    Radio ON, verify clear audio is heard from each audio speaker.
    ⇒ If audio is inoperative from all speakers, refer to Amplifier Circuit Malfunction.
    ⇒ If audio is inoperative from one or more, but not all, speakers or the audio emitted from the speakers is not clear, refer to the appropriate Speaker Circuit Malfunction.
    You really need to get DTC, the manual states it. Could be the amp, positive your fuse was OK?
  18. Remove Advertisements
