Passenger Air Bag Off...
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Passenger Air Bag Off... in Cadillac SRX / XT5 Forums; I'm getting an intermittent Passenger Airbag Off message when passengers are sitting in the front seat...from what the manual says, ...
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    802
    I'm getting an intermittent Passenger Airbag Off message when passengers are sitting in the front seat...from what the manual says, this means they have no airbag protection so...is this something I can easily fix myself or better to take it to a dealer or repair shop...also...does anyone know if this is still covered under any warranty...?
    Bill
    orandaberg Guest
    Re: Passenger Air Bag Off...
    Could be the sensor under the seat going out/loose connection. try a reboot, unhook the battery, wait a few minutes, you can try also to touch your + and - cables together unhooked from the battery of course. This is suppose to relearn your modules. it could be fixed but you need a manual. Do a search on here, others have talked about his
    Nov 2007
    ChicagoLand, USA
    802
    Orandaberg...thanks...I hadn't found a thread about my specific issue but your post gave me food for thought...I found a thread on the interwebz that provided the following for the CTS and I modified for our SRXs:
    Key in ignition, turn ignition to ON but not START
    Under hood there is a Fuse Block, remove cover and then remove Fuse for AIRBAG
    Go back to interior and turn ignition to OFF and remove key
    Replace AIRBAG Fuse
    Replace Fuse Block lid and close Hood/Bonnet
    Go back to interior again and insert key and start the engine...the AIRBAG should re-set
    So far, this seems to be working...I will keep an eye on it and report back from time to time or if there is any change.
    Cheers and thanks!
    Bill
    desmar's Avatar
    desmar is offline Cadillac Owners Member
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Did you get a message " service air bags" or something in those lines.
    Had this issue myself, did the resets, worked for awhile until got this message, the sensor under pass. Side went. Covered under warranty
    Nov 2007
    ChicagoLand, USA
    802
    Nope...no message...just would show the Passenger Bag was off with someone in the passnger seat...
    Bill
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Have you checked the electric connectors under pass side, unplug them check for dirt, rust, etc, clean them plug them back.
    See if it fixesvthe problems, just an idea
    Nov 2007
    ChicagoLand, USA
    802
    thanks...you have to remove the seat for this, right???...I haven't done it yet as for now at least mine is working...
    Bill
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    No seat removal, raise the seat as high as it would go. Look from the front under seat, you will see the cable connectors.
    Nov 2007
    ChicagoLand, USA
    802
    ok...thanks...mine's still working but that's an easy enough check to make...
    Bill
    Nov 2007
    ChicagoLand, USA
    802
    I seem to be freed of this issue except if I use Auto-Start with no one in the passenger seat (obviously )...then it remains that the passenger air bag is off if someone gets into the passenger seat (sometimes)...I still need to check the connectors desmar suggested...
    this car had the carpets shampooed before my purchase and it's possible something was jostled or bumped during the cleaning...
    Bill
    orandaberg Guest
    the air bag passenger will be off if no one is in it.
    Nov 2007
    ChicagoLand, USA
    802
    right...it's just not supposed to be off when someone IS in it...thanks...mine seems to only do this when I have used Auto Start...
    Bill
    Nov 2007
    ChicagoLand, USA
    802
    has anyone actually done this???...disconnected the connections under the passenger seat???...will I activate an airbag if I try this???...does anyone know which connector it is for the airbag, seat sensor???...there appear to be three underneath the passenger seat...two are larger and appear gray and one is smaller and yellow (would be my guess)???any help is appreciated...
    Bill
    ...they all appear connected and look fine...if safe I may try to disconnect and spritz with contact cleaner and lube but I'd sure like to not muck anything up...especially if I can get this serviced under my warranty...but if it is safe and as easy as disconnect, clean, lube and reconnect...I'd give it a go....:P
    Bill
  16. #14
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,837
    If you want to clean the yellow connector (SIR related), disconnect battery neg. cable for 10 min. before starting work. You may have a failing seat sensor pad causing the intermittent light. The Solstice forum has a 10 page thread about failure. If your warranty covers, let them do it.
    Been fixin' cars for 74 years
  17. #15
    Nov 2007
    ChicagoLand, USA
    802
    thanks...
    Bill
  18. Remove Advertisements
