What is this and how can I order a new one?
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, What is this and how can I order a new one? in Cadillac SRX / XT5 Forums; Here: and a zoomed out pic for reference: As you can see, it's starting to degrade and shrink from sun ...
    Scotterrific is offline Cadillac Owners Member
    Automobile(s): 2006 SRX
    May 2013
    7
    Here:
    As you can see, it's starting to degrade and shrink from sun damange. It looks easy to replace, I just don't know what its called and don't know where I'd order a new one. Any help is appreciated. Thanks.
    orandaberg Guest
    Re: What is this and how can I order a new one?
    look on tonkinonlineparts.com or even better write a PM to Rippy member on here. it a rubber seal for the gaps in the channels.
    http://www.tonkinonlineparts.com/sho...rimLevel=19237
    You do have a ultraview? If you order from Rippy he will give a discount to forum members
    May 2013
    7
    Ultraview is the fancy name for the sun/moon-roof, right?
    Ok, I'll PM Rippy, thanks.
    orandaberg Guest
    Yes it is
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    got your PM... but your inbox/outbox is full and I can't return a message
    I will need your VIN to start though
    Sep 2007
    Wilmington, NC
    13,969
    ok so I showed my wind and water leak expert what you're dealing with
    he said that what happens is the weatherstrips shrink
    both the side-to-side and the front to back so the gap appears and they pull apart from each other
    you can kind of see that the side-to-side weatherstrip turns 90 degrees at the corners and would slide into the front-to-back weatherstrip
    he said the correct repair is to replace all of them since just getting a side-to-side weatherstrip would still not be able to 'lock' in properly with the shrunken front-to-back part
    what makes it worse is that the panels that they're attached to are glued/urethaned to the roof and have to be chiseled off (or something like that) and you risk breaking them
    he also mentioned that these weatherstrips do not hold back water ... they are mainly for wind noise
    if you can get that weatherstrip to tuck back down and stay down you will probably save yourself a very large service bill and headache
    May 2013
    7
    Thanks so much. Wish I had you guys in Tucson! So I guess I'll just super-glue that thing down. Good to know that its not going to cause any leaks.
    Sep 2007
    Wilmington, NC
    13,969
    yeah that's probably the best course of action for the time being
  11. Remove Advertisements
