hood gaps
Results 1 to 10 of 10
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, hood gaps in Cadillac SRX / XT5 Forums; Does every 1st gen srx has that 3/4" gap between the dood,headlamps & grille, the hood looks ajar.most of GM ...
    desmar's Avatar
    desmar is offline Cadillac Owners Member
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    hood gaps
    Does every 1st gen srx has that 3/4" gap between the dood,headlamps & grille, the hood looks ajar.most of GM official pics there is no gap but srxs I've seen have this gap, not all though.
    Front bumper has been removed, I fix the gap between bumper & headlamps, the the bracket that the guide pin from ho slide into was blended allowing hl to be installed incorrectly. Reduce the hood & bumper gap by 1/4" by lifting/bending up the brackets were the bumper guide screws attache to fender, still have 1/2 gap but looks better.
    There's to much wait in/on bumper at front/bottom were drls are ,which cause the plastic bumper to sag overtime, it just may be need 2 guide pins to attach into aluminum bumper.
    orandaberg Guest
    Re: hood gaps
    Look on my thread Gap under headlight, Are you referring to what I have circled in yellow?
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    That's correct, the gap you encircle yellow. My srx is a champagne beige colour, so gap is very noticeable, hood looks ajar(open).
    The gap between hl(headlamp) & bumper I fixed it, I have 1/8" gap, by pulling the guide tab forward just abit in the body where the pin from hl slides into.
    I believe that the plastic stretched were the hl washer is, there is 2 tabs holding up the rest of the bumper
    Once again GM (Great Mistake) disappoints by being cheap & uncaring towards consumers.
    Great mistake on our parts for falling for their tricks.
    These wagons had great potential is they would have been continued developing them, but once again they killed it for more profit & gave us a rebage Chevy equinoxes/GMC torrents as premium Cadillac srx. They didnt even change the interior in the srx, sorry,yes they did GM painted the plastic vents frames chrome. Sorry for the rant.
    orandaberg Guest
    Re: hood gaps
    I have 1/8" gap, by pulling the guide tab forward just a bit in the body where the pin from hl slides into. What number in the drawing are you refering to.
    I can understand your ranting, I spent a lot to refurbish mine, this is a difficult truck to buy used and needs a lot of homework before buying one, if you get a good one its a good truck, bad one and your seriously in financial trouble, your lucky in the states and Canada with free shipping, here in Europe we have to pay shipping and taxes which can double or triple parts price. A tip for saving on taxes is to have it shipped to a repair shop instead of your home address.
    Sorry I went off topic
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    All is good, I'm from Canada but most good parts are from USA. So for example I cab buy all EBC brakes & rotors for the front wheels is about $500.00 us free shipping, but to get to Canada it almost triple in price plus taxes, & taxes & more taxes. The irony I live 1 hour from the USA border.
    In 1 year ownership the truck has consume close to $10000 in repairs al under warranty, I bought thus truck cause 1 owner, dealer maintained, no accidents all repair &services paperwork.
    Anyway, gap under hl with 1/8" gap is the best I can get it.
    Can figure out how to fix the gap from hood & bumper/grill.
    I couldn't open the pic you posted. How is the gap in yours?
    orandaberg Guest
    Re: hood gaps
    Hi
    Ithe drawing shows the headlight assembly and all suronding area, I am trying to figure out which guide pin you are refering too. Anyone else not see the drawing above thread?
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    In the diagram see the 1, it points to a square part. Now from this part ther are to lines one goes towards the guide pin at back, bottom of hl; the other line points towards fender, the tab is located @ back of fender, in between the bolts that retain the bumper cover, it has that #1 part.
    There are 3 nuts for hl, #2, attaches 2 fender, #3 attaches to the cross member, #4 attaches from side of hl to bumper, #1 is the guide pin at bottom rear of hl.
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    orandaberg Guest
    Re: hood gaps
    How did you reach this? Removing the inner fender liner? Removing the light? Removing the whole fascia?
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Quote Originally Posted by orandaberg View Post
    I did in steps
    1. Remove bumper cover, the whole thing, is easier to work.
    2. Remove headlights
    3. Inspected all points that hl attaches to body. There is 1 bolt from headlamp that goes into bumper, & right below is the pin that secures hl into fender/body.
    4. Bend the metal pin tab with a pair of pliers towards front of vehicle just a little & gentle, it's very soft sheet metal.
    5. reinstall hl, do not tighten screws.
    6. Reinstall bumper fascia with just the guide pins, donot tighten nuts.
    If you have othe person to assist in aligning ul & bumper fascia to see the gap.
    7. If gap still there, repeat step 4, keep doing this until you reach desire result.
    8. I recommend to replace any lights that have not been replace recently.
    9 reasemble everything, make sure all nuts & bolts are tight.
    It's a pain in the rear end but is worth the efforts.
    My pass. Side is hl is flush with bumper, had a 1/32" gap; drivers side has just over 1l8 of gap, will try on Sunday to get it same as the other side. Even the hood and bumper fascia improved it has just over 1/2".
    Oh I forgot if available there buy some replacement black retainer tabs
  13. Remove Advertisements
