2008 SRX front differential mystery
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By alk247
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2008 SRX front differential mystery in Cadillac SRX / XT5 Forums; While driving through a monsoon last Friday, the traction control seemed to becoming confused when ever I encountered standing water ...
    Nikowon is offline Cadillac Owners Member
    Automobile(s): 2008 SRX
    Aug 2013
    Gulf Breeze, Florida
    14
    Unhappy2008 SRX front differential mystery
    While driving through a monsoon last Friday, the traction control seemed to becoming confused when ever I encountered standing water and the front tires aquaplaned. Every so often the front wheels would jerk and clunk from side to side until the front differential jammed and flew into internal pieces. Being on an interstate I slowed to the right lane and proceeded on slowly seeking an appropriate off ramp. Suddenly the rear wheels lost their drive and I coasted to a stop. By then even the park position did not keep the vehicle from rolling forward or backward. My SRX is now in a transmission shop 500 miles from home waiting for a final estimate. I am puzzled as to what might have gone wrong with the traction control and front differential. No hint of a problem prior to the event. Have never experienced anything quite like this in decades of driving. Any ideas as to the cause would be appreciated. I pretty much know what the effect is.
    nascarnation is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    68
    459
    Re: 2008 SRX front differential mystery
    I don't have any insight into the behavior of the electronics.
    But mechanically, the transfer case has an "open differential" design, similar to a non limited slip rear axle.
    In a 2wd vehicle if one wheel spins out, drive is lost.
    So in this case if your drive to the front axle fails (freewheeling due to some type of front differential failure) the drive to the rear axle will be lost also.
    The fact that engaging the park mech would no longer lock the driveline says the front end of your transfer case was "disconnected".
    Aug 2013
    14
    Thanks for the response, but I was told on this vehicle there is no tranfer case.?????????
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    If you have a front differential then you have a transfer case. There just is no sensible way around it.
    Bill
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    37
    144
    Did you get final diagnosis/repair bill from the transmission shop?
    Aug 2013
    14
    Yes. Just received a call from the shop. They believe the failure of the front differential was due to loss of fluid. Replaced the entire unit. $2,259. They also explained the exact same reason for rear wheel drive failure as stated in the response above. When you lose drive to the front the rear becomes inoperative as well. Seems to me to be a STUPID design. Good for the tow companies. Bad for the stranded driver. Modern technology is beginning to confuse this old guy. Thank you all for your input. Now a 500 mile trip back to the scene...nick
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Not a stupid design at all, they base it on the fact that your wheels should be on the ground and stuff does not break. If it was not the case then you could not have the compact spare and you would need electronic locking diffs for TC to work.
    So no it is not a cash grab for tow companies, just a common way to do things.
    bsw357 is offline Cadillac Owners Member
    Automobile(s): 06 SRX awd 3.6
    May 2014
    3
    My 06 SRX 3.6 AWD was same thing, loss of the fluid. A little less than 120k miles and didn't have gear oil in there at all. Pinion gear was excessively worn so was the ring gear, eventually broke the teeth off of both gears. I got lucky as I bought the replacement front differential with 65k miles for $200 on ebay, including the shipping! Also the factory manual said to only remove the differential and the driver's side inner shaft( that goes through the oil pan) as an assembly, I managed to pull out the shaft by using a pair of medium sized channellock once I got the differential dismounted on the passenger side. it enabled me to drop the differential housing to the bottom, the pinion stem side first. I did have to lift the engine and lower the subframe 3 or 4 inches then forced the engine to the driver's side probably about 3 inches with a prybar but didn't have to disconnect any brake lines or hoses. I did take off couple of 10mm head m6 screws that's holding lines and bracket for washer tank( on the tank side only) but no line connections at all. Strut tower bar should be removed, watch for ac condenser bottom mount positioning and radiator top mount positioning when mating the subframe back on the main frame. and the front differential can only be dropped or go back in, in same orientation. that's the stem side down. I did try different ways but just didn't work. I hope this could save someone some time. I guess I received the used differential kind of dry, but it didn't even take a quart of gear oil to fill up the front differential full. All I had to buy was the used differential and a quart of gear oil.
    Aug 2008
    Indianapolis
    68
    459
    I'm curious on these front diff failures due to lack of lube. Do you park in a spot that would show the oil leak?
    graham69 is offline Cadillac Owners Member
    Automobile(s): srx4
    Jun 2016
    9
    1
    I have a 2008 srx 4 with more backlash in the front diff than in the rear (2 to 3 times more) and i have the feeling of trailer hitching when cruising also at slow speeds can hear a clacking sound lick gears.
    bjoernwidell is offline Cadillac Owners Member
    Apr 2015
    4
    I have a SRX 4WD from 2008, after reading this thread I become worried and I like to check the oil level in the front differential.
    Vhere is the level plug located?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    If I recall, it's on the right side of the case, facing to the rear.
    Been fixin' cars for 74 years
    alk247 is offline Cadillac Owners Member
    Automobile(s): SRX 04
    Nov 2016
    61
    1
    First of all - thanks to bsw357 for detailed post. I just replaced from diff on my SRX 04. I did it slightly differently. Here are the steps I did.
    1. As was stated by bsw357, I disconnected washer bottle bracket - right side wheel well plastic cover need to be removed to get access.
    2. Removed right side strut module - need to disconnect upper control arm from the steering knuckle (I did not find another way to it, but grinding down the nut on the upper ball joint).
    3. Disconnected tie rod end from the knuckle (not sure if this was necessary).
    4. Removed passenger side drive shaft.
    5. Dropped sub frame on passenger side (removed bolts holding sub-frame to the body on the passenger side and just loosened them on the diver side (there are three on each side).
    6. Disconnected front propeller shaft from the diff.
    7. Pulled the diff to the passenger side above sub-frame (it helps if the second person pushes down on the sub-frame).
    8. Installed new diff and put everything back together.
    If you are getting used diff, it is very likely that drive shaft seal will have to be replaced, so have one ready. Upper control arm and axle nuts are not reusable, so get them ahead of time as well. Special tools that are not normally found in standard sets - deep 18mm and 22mm sockets.
    Since I had to remove the strut, had to do alignment afterwards. Add $100.
    vettemech likes this.
  16. Remove Advertisements
