Gap under headlight
Results 1 to 14 of 14
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Gap under headlight in Cadillac SRX / XT5 Forums; On the left side I can slide a 1/4 of my 4 fingers under the headlight, on the right about ...
    orandaberg Guest
    Gap under headlight
    On the left side I can slide a 1/4 of my 4 fingers under the headlight, on the right about a 1/8 th. Clearly if I lift under the fascia the gaps close, any ideas why the big difference, being a black fascia you cannot really tell but if it where a off color it would show up. Hood lines are straight,hood gap is straight. Lights are straight. Ideas?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    The bumper stretch maybe got hung up or the plastic pins damaged up top
    orandaberg Guest
    Re: Gap under headlight
    Thanks
    The bumper stretch maybe got hung up?
    plastic pins damaged up top?
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    799
    S'funny but my 2008 is like yours...my buddy, who looked over mine prior to me buying (body and fender guy who is an insurance adjuster) though maybe the front had been worked on before on it...this was backed up bu a bit of paint on what should have been an unpaired bolt head under the hood...
    Bill
    Oct 2012
    975
    Sorry I was half asleep lol I meant maybe the bumper stretch from being caught on something or the plastic retainers above the grill are stretched out.
    nhramike57's Avatar
    nhramike57 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Escalade EXT , 2007 SRX
    Sep 2010
    Alberta Canada
    55
    106
    These urethane bumper covers are very flexable and the location of the pins to mount them might be out enough to cause your missalignment. I would pull a few of the pins out from around your headlight and see if the gap gets any better. If so i believe the body shop supplies have larger diameter plastic pins..a little enlarge drilling and a new pin might be the trick l
    orandaberg Guest
    This is all that holds the fascia to the front, nothing under the head lights that would give support. Having a new grill eliminated the center #3 pins, however the T rex grill is too light to cause a sag under one light, and a note: the gap was there before I replaced the grill
    Does everyone have the gap I circled in yellow? Note gaps are the exact same size on both sides, however if you push the fascia from the bottom to compensate the gap under the left light it closes the gap, so fixing one side would make the gaps between hood and fascia uneven
    Here is a drawing of the headlamp
    jgodfrey82 is offline Cadillac Owners Member
    Automobile(s): 07 SRX NorthStar - just purchased, and loving it!
    Jul 2011
    71
    My v8 with sport fascia has the same gap.. I know it had front end work in its past life, so ive just ignored it, seems to be on pretty well even with the gap.
    orandaberg Guest
    So I can assume its just poor quality material that sags,deforms over time (on mine), or if its replaced it may not fit the original cars form. This truck was checked and was in no accident (reported anyway). Just something one has to live with.
    orandaberg Guest
    As seen above I removed the 2 nylon pins holding the fascia to the cross member, got a hydraulic jack with a wood block and lifted the center of the fascia till the gaps closed, drilled a hole for the sheet metal screw with rubber washer to hold in place, note to the right how far the original hole moved, the hole is covered.
    No more gap, did it to both sides. Fascia is very solid and has no movement up and down now
    orandaberg Guest
    I got to thinking about what holds these lights in place, below is a shot taken inside left side of grill, the screw facing the viewer holds the light in place, if its loose(as was mine it can cause a gap on inner corner as mine did. I loosened the 2 top screws on the light just enough for movement. pressed firmly down the top of the light and closed the gap as much as possible, tighten screws starting with the side one. Result was the same as I had done using the above method drilling new holes, so now I have it back to OEM with plastic retainers. Note I have a T-REX grill which allows full access behind the grill, the OEM maybe more problematic. You can see in the pic where the ring was and where it is now, quite a difference.
    desmar's Avatar
    desmar is offline Cadillac Owners Member
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    That's great u fix it. I guess my way is more complicated
    How the hood gap
    orandaberg Guest
    Its the same both side just under 0.5" No way to close the gap between hood as the fascia is as high as the light will allow. I have to look at the striker, maybe it can be lowered? but then you need to take into account the level of the front hood in comparison to the level of the top of the head light. Making sure its level and not below the top of the headlight
  16. #14
    desmar's Avatar
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Gotcha, but remember hoodlatch is also adjustable by about 1/2" if I remember right., as well the 2 hood shoppers are adjustables.
  17. Remove Advertisements
