EVAP Canister Purge Solenoid Valve ??
Results 1 to 10 of 10
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, EVAP Canister Purge Solenoid Valve ?? in Cadillac SRX / XT5 Forums; Just replaced this a few days ago, felt somewhat of a change in idling, but know back to the square ...
    drod777 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6
    Oct 2012
    24
    56
    Just replaced this a few days ago, felt somewhat of a change in idling, but know back to the square one. How can you tell if this part is defective or if it supposed to click every second? I am pretty much at my last straw with this car.......
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Its not suppose to click rapidly that's when you know its bad. Mine was doing that replaced it and it was good to go.
    Oct 2012
    24
    56
    Re: EVAP Canister Purge Solenoid Valve ??
    So I guess I need to take it back to the place I bought it since it went out once again
    Oct 2012
    975
    Yeah it is possible to have bad parts right off the shelf now if it does it again you have another issue either electrical or vacuum. Check the lines for breaks but unlikely since there isn't a hissing noise or check engine light mentioned
    Oct 2012
    24
    56
    Ok can anyone tell me if this part should be sucking from the line that comes from the Evap Canister every second. I removed the line real quick that connects to EVAP Canister Purge Solenoid Valve and its just intermittently sucking?? Or should it be an ongoing suck ??
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,798
    Your DTC will help diagnose.
    Been fixin' cars for 74 years
    Oct 2012
    24
    56
    Ok will go to the auto parts store later today to show if any pending dtc
    Oldman Cadillac is offline Cadillac Owners Member
    Automobile(s): '05 SRX
    Apr 2008
    Cincinnati, Oh
    34
    40
    I just got a code for an EVAP problem. The SRX won't start after getting gas. Where would I find the solenoid on the engine? And if you don't mind how much was it? I don't want to do a $99 "smoke" test if I can fix it myself. Thanks
    Oct 2012
    975
    The purge solenoid is on the passenger side of the intake manifold on the v6 yours might be the evap parts around the gas tank
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,798
    What was the code #?
  13. Remove Advertisements
