R & R Fuel Pump
Results 1 to 5 of 5
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, R & R Fuel Pump in Cadillac SRX / XT5 Forums; My son has a 2004 V6 with a bad pump. Any ideas on labor time to R&R pump? Also is ...
    Harry Davidson is offline Cadillac Owners Member
    Automobile(s): Seville
    Jun 2012
    6
    R & R Fuel Pump
    R&R pump?
    Also is this a job an average shade tree mechanic can do?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Side shops run around $500+ dealer will be way higher. They aren't too difficult if you are comfortable enough with your skills definitely go for it. Haven't done one on mine yet but looked under just now looks typical some hoses connectors couple straps etc a good jack with a piece of plywood to support the tank hopefully your low on gas a full tank is fun to say the least
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: R & R Fuel Pump
    Before you start this, PM me for a PDF to remove tank. Can be done by competent back yard mechanic but there is a lot involved including dropping rear suspension.
    Been fixin' cars for 74 years
    Mikes8850 is offline Cadillac Owners Member
    Automobile(s): 2004 srx v8 awd
    Jul 2015
    Ny
    12
    Re: R & R Fuel Pump
    Hi Glake89, can you send me this PDF as I was under car yet again repairing rear drive shaft problem, while wife was switching key on to put in neutral I was able to hear my pump making unfavorable rattling noises. Thanks, Mike......04 AWD V8 SRX
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: R & R Fuel Pump
    Before you start this, check fuel pressure, you may not need a new pump. Second, don't let fuel get below 1/4 tank as pump uses fuel for cooling, unless you're going to replace the pump. Does your car have the rear air shocks? It may be the compressor you're hearing. Anyway, you need to PM me your email for any PDF.
  8. Remove Advertisements
