suspension issues - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, suspension issues in Cadillac SRX / XT5 Forums; Go to O'Reilley's and have them check the code, they should have one that will pull the ABS codes (be ...
  1. #16
    xboxman72 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX4 V8 Sport Package
    Aug 2012
    45
    56
    Re: suspension issues
    Go to O'Reilley's and have them check the code, they should have one that will pull the ABS codes (be sure to tell the kid to set the machine correctly). Most likely issue is one of the front wheel bearings.
    Does the warning light stay on or does it come and go?
    I recently replaced both front struts on my 2008, they were $55 each on Amazon. I also replaced a bad bearing to correct the "Service Stabilitrak" message. The parts are cheap if you can do the labor your self.
  2. #17
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Quote Originally Posted by mjcaddy View Post
    thanks guys for all the replies, most got this problem solved with the steering wheel position sensor replaced but I had issues with the wheel hub before so that made me think it can be anywhere now.
    I'll have to take it to the dealer, the only thing is i don't have time, I'll see if i get anytime off work this Friday just to drop the car there.
    cheers
    MJ
    Hi MJ,
    I apologize for any trouble you have to go through in getting your vehicle to the dealership. Please keep me informed if you are able to get your vehicle into the dealer and the outcome of your situation. If you need my assistance for anything, don't hesitate to contact me via private message.
    Regards,
    Laura M.
    Cadillac Customer Care
  3. Remove Advertisements
