Replaced an ignition coil and the spark plugs now it won't stay on???
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Replaced an ignition coil and the spark plugs now it won't stay on??? in Cadillac SRX / XT5 Forums; I had a code for a miss in the 2nd ignition coil. I decided to replace it and change the ...
    krmarti1 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX
    Jul 2013
    3
    I had a code for a miss in the 2nd ignition coil. I decided to replace it and change the spark plugs. After finishing it will start but it doesn't stay on. I've rechecked my work, even tried putting all the old parts back in, but still it won't stay on!! I need some advice. What went wrong???
    Note: I always disconnect the battery when I'm working on a vehicle. A friend thought maybe I tripped an anti-theft feature. If that's what it is... How so I reset it?
    Thanks for any and all suggestions!!!!
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: Replaced an ignition coil and the spark plugs now it won't stay on???
    6 or 8? Are you sure all intake ducting from MAF to engine is properly secured, nothing left un-attached?
    Been fixin' cars for 74 years
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Intake gaskets not torn or misaligned? Could definitely be the maf or intake not hooked up
    Jul 2013
    3
    It's a V6. None of those other issues apply. I spoke with a mechanic and they said it is most likely the anti theft system too. It's preventing the fuel pump to work. Any other suggestion???
    Oct 2012
    975
    That's odd for the alarm to lock down like that have you checked all the fuses in the engine compartment and by the second row of seats can you hear the pump did you accidentally hit the ecu with the manifold?
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,833
    Anti theft prevents engine crank. Is the AT icon on?
    Then try to start with MAF disconnected.
    maddoggyusa is offline Cadillac Owners Member
    Sep 2010
    40
    explain what you mean by "won't stay on"? Does it run rough or does it shutdown after a certain amount of time? If so, how long does it run before it shuts off?
    Are you tripping any codes?
    Jul 2013
    3
    Thank you all so much. You were right after all. There was a tear I hadn't noticed in the intake gasket. I replaced it and all is well. Thanks again for your time and advice!
    Oct 2012
    975
    Quote Originally Posted by krmarti1 View Post
    Glad to help I would spend the money yo get the metal ones from the dealer the aftermarket paper ones suck.
  12. Remove Advertisements
