V8 Coolant Temperature Sensor Location?
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, V8 Coolant Temperature Sensor Location? in Cadillac SRX / XT5 Forums; I have a 2008 AWD V8 SRX and recently every time it rains, my temperature needle drops to zero, then ...
    xboxman72 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX4 V8 Sport Package
    Aug 2012
    45
    56
    I have a 2008 AWD V8 SRX and recently every time it rains, my temperature needle drops to zero, then the display says the engine is too hot and kills the A/C. I can resolve this by disconnecting the battery for a few minutes after the rain stops.
    I assume some connection is getting wet or the sensor needs to be replaced. I searched but cannot find a reference to it on the V8.
    Can anyone point me in the right direction?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,837
    Re: V8 Coolant Temperature Sensor Location?
    At the rear of the right cyl head, #711.
    Been fixin' cars for 74 years
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    Temp sensors are thermistors. They never fail and then recover in my years working with them and when they do fail they will always indicate an extreme value as they develop a short or open internally. Sounds like you have a bad connection someplace that gets wet when it rains.
    Bill
    Aug 2012
    45
    56
    That picture is on the passenger side by the firewall? I'll have to look harder. I don't see how that location is getting wet though, I did notice water from the windshield is running under the plastic cowl on the driver side and down the firewall behind the fabric insulation in the engine compartment.
    Aug 2012
    45
    56
    I located the sensor from under the car but could not get my hand anywhere near it without removing the drive shaft so, I coated the ends of the wires where they go into the connector with some RTV using a stick. We'll see what happens next time it rains.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,837
    If you remove the plastic engine cover you can get to it.
    Aug 2012
    45
    56
    I could not reach it from the top even with the cover off, maybe i'll take another look but I did what I wanted to do anyway. Hopefully it stops for now.
    frankcottnj is offline Cadillac Owners Member
    Automobile(s): SRX
    Jun 2013
    52
    47
    Bill do you know where the sensor is on the 3.6? I assume it's by the thermostat but don't see it.
    frank
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,837
    It's just to the rear and about level with the oil filter housing.
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    800
    Quote Originally Posted by frankcottnj View Post
    frank
    The sensor is located near the front in the driver's side head. The thermostat is at the rear of the pass. side head.
    Automobile(s): SRX
    Jun 2013
    52
    47
    Thank you, I'll start on this now. Hope all goes well and no engine P0119 codes.
    frank
    Wow, this plug is it the top 1/4 inch tab that I lift off to disconnect? I have not familiar with this plug type and it looks like it has the one lock tab on the top. Please advise this will be my last plea for help. I just don't want to break the plug.
    frank
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,837
    Hang on Frank, pics coming.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,837
    Red line points to release tab, press down. If there's a gray tab, slide it out first, it's a connector assurance lock.
  16. #14
    Automobile(s): SRX
    Jun 2013
    52
    47
    This is the best forum I've ever been on. Thank youi. So I am gong to squeeze or press down on the tab. I was glad to see this because I was going to pick it up with a screw driver tip. Thank you
  17. #15
    Mr1drfull is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac STS AWD V8
    Aug 2014
    1
    I just had the same problem as Xboxman72 today on my 2007 STS AWD V8. It wasn't raining or wet out, sensor wire looks good, instrument panel said engine hot, killed AC and defroster. So I searched this forum for answers and figured I should change coolant sensor. I bought sensor and was told it was an easy swap, by the thermostat housing they (Auto Value) said. I finally find sensor (I think, back of pass side head) but it looks like it will be a fairly involved process. I am guessing the whole right side plastic valve/spark plug cover has to be removed to access the very tight behind the head area. I finally did the disconnect battery terminal for a temporary fix and will do the swap another day. Did you (Xboxman72) or anyone else with this problem, resolve this problem and if so did you actually change the sensor?
    Thanks for your time
  18. Remove Advertisements
