Towing = low RPM 'shuddering' + flashing check engine light
Results 1 to 13 of 13
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Towing = low RPM 'shuddering' + flashing check engine light in Cadillac SRX / XT5 Forums; 2008 V8 w/V92 I was towing this past week and had three instances of low RPM 'shuddering' or 'pulsing' that ...
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    37
    144
    2008 V8 w/V92
    I was towing this past week and had three instances of low RPM 'shuddering' or 'pulsing' that lasted approx. 10 seconds. The check engine light was flashing and then cleared once the vehicle was operating normally.
    No DTC's found with an enhanced scan tool. No other driving symptoms noticed.
    After a forum search my best guess is a sticking torque converter. I'm going to attempt a filter, and fluid change in the transmission. Any other suggestions?
    nascarnation is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    69
    498
    Re: Towing = low RPM 'shuddering' + flashing check engine light
    My experience base is getting old, but I thought it took a good number of drive cycles to erase codes.
    That's the key to diagnosing intermittants.
    Perhaps one of the techs on here will chime in.
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    Flashing check engine light = type A misfire occurring. That is the only thing that will flash that light. What brand and model scan tool were you using to pull the codes?
    JayT F1's Avatar
    JayT F1 is offline Cadillac Owners Member
    Jun 2012
    73
    Quote Originally Posted by rlh6805
    I thought it was strange that there was no codes.
    Innova 3100 was the tool. Checked for regular codes and gm specific enhanced dtc's
    Another thread mentioned the torque converter issues would cause a misfire scenario. I guess it could be a coil pack as well......
    Drove the car all day today with no issues.(non towing)
    Jun 2012
    51
    326
    Quote Originally Posted by JayT F1 View Post
    That is an shade tree mechanic scan tool. It's ok, but may not have the capability to send the ecu the correct DTC request. A proper scan tool will have the capability to read the misfire counter pids so a tech can see the cylinder(s) misfiring live. There may not be any codes set currently but there will be some in history that don't clear unless a clear codes command is sent to the ecu. The vehicle has an issue where one or more of the cylinders misfires during heavy load conditions (towing). You should get it checked out professionally.
    Automobile(s): NONE
    May 2012
    37
    144
    Thanks for the reply.
    As a side note, what is an option for an over the counter tool that can accurately diagnose our vehicles?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,947
    I'm going to hazard a guess that you were in cruise or light pedal. What happened is the torque converter lockup solenoid was chattering (sticking). Can be avoided by heavier pedal application. New fluid will go a long way to correct. And any type A code will cause flashing light and that means get service right away- unless the light goes away.
    Been fixin' cars for 74 years
    Jun 2012
    51
    326
    Quote Originally Posted by glake89 View Post
    This is not true. Type A refers to the misfire type not the code type. I am 100% positive that the ONLY thing that will cause the light to flash is a misfire. I write diagnostic scan tool code for a major OE so I know what I am talking about.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    I stand corrected, my excuse, just finished a 4 HR drive, top down,>90deg.
    Automobile(s): NONE
    May 2012
    37
    144
    Trans Fluid and filter booked at the shop on Wednesday. I'm going to swap the plugs with new Delcos and inspect/test all the Ignition Coils for good measure. I'll report back as I plan on towing again this weekend.
    Glake is correct that I was in a light throttle position when the problem occured.
    How long will a plug change take me with the V8?
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    A "type A" DTC is a emission related code that lights the CEL and stores a freeze frame DTC after one failed driving cycle. A"type B" DTC is a emission related code that sets a pending DTC after one failed driving cycle and clears after one successful driving cycle. It will light the CEL and store a freeze frame DTC after two failed driving cycles.
    Bill
    JayT F1's Avatar
    Jun 2012
    73
    With transmission service complete at gm dealer, i towed a ~2600lb load in extreme heat for 4 hours today. No relapse of the symptoms. Problem solved? Perhaps........
    Spark Plugs ordered from rockauto.com for good measure. (Great prices on the delcos btw.)
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Glad the fix was this easy. It must be a relief! PJ
  16. Remove Advertisements
