Leeft rear turn signal on a o7 SRX
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Leeft rear turn signal on a o7 SRX in Cadillac SRX / XT5 Forums; I (foolishly) installed a trailer hitch myself. The actual install of the hitch was easy. The wiring harness on the ...
    OhioDave is offline Cadillac Owners Member
    Automobile(s): 2007 SRX V6
    Jun 2013
    7
    I (foolishly) installed a trailer hitch myself. The actual install of the hitch was easy. The wiring harness on the 07 has been a nightmare.
    I unplugged the connector over the left rear exhaust and turned on the left turn signal. Using a circuit tester I checker which terminal was getting power. I must have shorted something out because the left rear turn signal no longer works.
    I looked at the fuses under the left rear seat and they are good. I removed the small panel under the steering wheel looking for a turn signal modulator as I read the 04 model had them but I found none. Any help would be welcome.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,877
    Re: Leeft rear turn signal on a o7 SRX
    Fuses are in right rear fuse block, labeled 'spare, 10A'
    Been fixin' cars for 74 years
    Jun 2013
    7
    Thank you glake89,
    I checked the fuses in the right rear fuse box (under right rear seat) and they all looked good.
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    The fuses for the left side rear turn signal are located in the right rear fuse box. And it is marked "spare." Have I got this right? Someone at GM must stay up late at night to plan this stuff out. PJ
    Jun 2013
    7
    I looked at all the fuses there and they were good. However, I noticed that every fuse location marked "spare" was an empty slot.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,877
    Do you remember what color wires you tested? Turn signal lamps are run by a relay, also in RR fuse block also labeled spare. You should also now have an inoperative lamp DTC. Does the brake light also not work? This is getting interesting!
    PJ, right! all this stuff goes through the body control module. Oh, for the simpler days.
    Dave, then check the BCM fuses, #3 is in RR block and several are in underhood fuse block.
    Jun 2013
    7
    Running lights work. Turn signal and brake light does not. The wire was blue.
    Update.
    With glake89's guidance it appears that it's the BCM5 under hood. WooHoo. Well I might be celebrating too soon. I will find out pronto.
    That was it glake89. BCM 5 underhood. I owe you sir. Thank you.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,877
    Anything for a fellow Buckeye.
  11. Remove Advertisements
