Help identify airbag year
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Help identify airbag year in Cadillac SRX / XT5 Forums; Can anyone help what year this airbag is used from... 2008 to ? I bought this a while back for ...
    orandaberg Guest
    Can anyone help what year this airbag is used from... 2008 to ? I bought this a while back for my 2008 wheel, cannot identify any part number shown on the bag
    Thanks
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,870
    Re: Help identify airbag year
    I would think a dealer could read the bar code and that would tell you what year.
    Been fixin' cars for 74 years
    orandaberg Guest
    maybe state side not here, tried that, but good suggestion!I assume the bar code is the same as the bold numbers above, or maybe the bar code has other info
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,870
    I think barcodes don't have letters.
    orandaberg Guest
    Maybe I should rephrase the question, does anyone else have connections like these and if so what year is your SRX
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    If you have an android phone then maybe a bar code reader app would work.
    Bill
    orandaberg Guest
    Here is a 2010 to 2013 airbag, so mine has to be 2008 to 09, I have read there were 3 different color codes the 2004 to 07 being purple/gray, the following being pink/white, and last turquoise/yellow
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    804
    It appears this inflator was manufactured by TRW in Mesa AZ. Many many years ago I actually toured one of their facilities in Mesa. A couple years or so ago they were trying to sell the facilities. Don't know the outcome. Which leads me to your question.... you might try contacting TRW (try www.trwauto.com for a link). Many someone could guide you to what vehicle/model years this inflator was use.
    orandaberg Guest
    Thanks
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    from what i can see in the parts catalog there are two steering wheel harnesses for the 2008-2009 SRX
    one is for NP5 option code and the other is for either N31 or NR7
    but that doesn't mean that the connectors for the airbag are different (they shouldn't be)
    especially since those RPO codes have to do with heated steering wheel options
    the parts catalog isn't even really clear if these steering wheel harnesses have the airbag connectors on them
    so....
    what I can tell from the service manual is that the connector for the airbag in the steering wheel on a 2008 SRX should look like this
    and that looks like the second picture you posted (the one you say is 2010+)
    the connector below is for a 2009 SRX
    looks like the one you've got is from a 2009
    what is clear from the service manual is that to get these connectors you have to purchase a whole harness
    this is typical with airbag parts and body harnesses
    GM does not typically want anyone to modify/repair body harnesses (especially airbag ones)
    orandaberg Guest
    Its the clock spring that needs replacing to match the connections. Find a clock spring for SRX 08-09 and it will match.
    So the connector in the second drawing has to be flipped upside down so the crescent is pointing up not down on the white pin. I have a clock spring but the crescent on the white pin is down also like the drawing, in order to connect one would have to flip the pin upside down.
    I can post a pic connected in a little while to show if this is correct.
    Sep 2007
    Wilmington, NC
    13,986
    so there's apparently two clock springs again to match the steering wheel options
    #19168048 (w/ n31 or nr7)
    #19168049 (w/ np5)
    they both say that they come with the harness
    list prices are $267 and $215 respectively
    orandaberg Guest
    Here is a pi showing the air bag and connections above
    In order to connect I have to flip the connections as shown, to me I would have thought the wires would be down not over
    According to the manual these pins match, so flipping it as in the pic above will match the airbag
    Thanks Rippy for your help! Once again you go beyond.
    I just found a classmate from class of 91 from CFCC. Hope to come to Wilmimgton soon! Sorry members to go off subject
    Please feel free if anyone else has a 08-09 SRX, if they feel like pulling off or have pulled off the airbag, tell me if the connections to the airbag have the wires going down or over as shown in the pic above.
    Thanks
  16. #14
    Sep 2007
    Wilmington, NC
    13,986
    first two pics are not showing up (stupid photobucket ... why i always use imageshack)
    PM me your email and I'll shoot you a pdf from the service manual ... close reading might answer your question about routing of the connectors/wires
  17. #15
    orandaberg Guest
    Anybody else not see the pics Rippy mentions?
  18. Remove Advertisements
