Air conditioning problem
Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By 08SRX
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Air conditioning problem in Cadillac SRX / XT5 Forums; Hey guys any help would be appreciated, in my 2008 srx the driver side climate control is blowing colder air ...
    Benzalac is offline Cadillac Owners Member
    Automobile(s): 2008 SRX
    Jun 2013
    28
    3
    Hey guys any help would be appreciated, in my 2008 srx the driver side climate control is blowing colder air than the passenger side, which is really confusing me, any ideas what could be going wrong?
    Sent from AutoGuide.com Free App
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: Air conditioning problem
    What are the left and right temperatiure controls set at? You have dual climate control up front. PJ
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    Right/Left blend door servo? A diagnosis with the proper scan tool may pull up some codes from the HVAC module.
    Jun 2013
    28
    3
    Pj both climate controls are set at the same temperature 20 degrees Celsius , just the drivers side vents are blowing colder air than the passenger side.
    RJ I don't really understand what you are saying, there are no lights or service Codes that pop up when I start
    Feb 2010
    New England
    2,005
    Someone can help me out here. But there are sensors in the dash that measure hvac requirements to achieve the set temperatures, left and right. For example, sun beating down from the left of the vehicle onto the driver would necessitate colder air from the left side vents to achieve the same set temperature for the driver versus the temperature blowing from the right side passenger vents for the front passenger not in the direct sunlight. I think there are two sensors on the SRX dash, right and left. My Oldsmobile Aurora (1998) had three dash sensors.....the third was center dash. PJ
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    792
    Add to the list of suggestion... if your system has a low refrigerant charge it can cause a temperature differential side to side.
    Jun 2012
    51
    326
    Quote Originally Posted by Benzalac View Post
    With the proper scan tool you can access the HVAC module and see if there are any codes set. There will also be output control functions to let you determine if the servos are working properly. The GM Tech 2 would be this tool. Also, there are no lights on the dash that would light up due to a fault in the HVAC system.
    drod777 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6
    Oct 2012
    24
    56
    I have the same issue as well. The drivers side has remarkable temp difference then the passengers side.
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,000
    I had the same issue as well. At first the passenger side was just blowing warm air, while the drivers side was still cool. Now a month or so later, driver side is blowing warm and passenger side is hot. I am leaning toward low or worn refrigerant and am checking it out in the next day or so.
    08SRX's Avatar
    Jun 2011
    1,000
    Re: Air conditioning problem - UPDATE!
    Guys,
    Just wanted to send an update on this. In my case this was not a blend door issue or anything else mechanical, but simply low refrigerant. It is ice cold again after a top up. So it looks like lack of refrigerant will manifest itself first by blowing warm air on the passenger side.
    Hope this helps.
    Whiplash_89 and TimRSRX777 like this.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by 08SRX View Post
    Guys,
    Hope this helps.
    Hey 08SRX,
    Thanks for updating everyone and sharing this information. I am glad your air conditioning unit is working correctly again. If another concern or issue arises, don't hesitate to contact us.
    Regards,
    Laura M.
    Cadillac Customer Care
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    They beat me to the freon issue lol. Another thing to consider is based on the air temperature in your area you sometimes needs higher psi to provide adequate cooling. For example my Ac pressure was 35 in Georgia but in central Texas when its 100+ degrees I have to set all my Ac jobs to 45psi. Good thing is adding freon is cheaper than the actuators behind the dash
  15. Remove Advertisements
