Just did the dumbest thing ever!! Help
Results 1 to 2 of 2
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Just did the dumbest thing ever!! Help in Cadillac SRX / XT5 Forums; I can't believe I just did this but I have an 04 SRX and I couldn't get me key out ...
    Ghas is offline Cadillac Owners Member
    Automobile(s): 2004 SRX
    Jul 2013
    42
    I can't believe I just did this but I have an 04 SRX and I couldn't get me key out of the ignition. Looked through the forums and it seems like it is a steering lock issue. I tried disconnecting the batt, starting restarting, an even unscrewed the screw under the steering column to try to manually pop the spring but couldn't do it. So here's where I got stupid. I didn't want to leave the car in the driveway unlocked with the key in the ignition but didn't want the battery dead from the accessories stuck on either so I locked the doors then disconnected the battery then closed the hood. Why did I close the hood? By the way I have one key for this car.
    Any idea how to open the hood from the outside?
    Can't believe I just did this
    Thanks for any help
    Jul 2013
    42
    Re: Just did the dumbest thing ever!! Help
    Ok I'm still an idiot but I got the hood open pretty easily. If it ever happens to you just look through the grill find where the cable pulls from, then I took a coat hanger and hooked it and pulled and it opened.
    Also the tip for getting the key out is great. I couldn't see it at midnight but there is little hole in the center of a metal piece under the screw under the steering column. Press it with something small and the key pops out. Amazing! I still need to get the steering lock fixed since I doubt my wife will enjoy this process every time she goes somewhere
    Thanks for the helpful advice
