Horn Inop
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Horn Inop in Cadillac SRX / XT5 Forums; My car failed our state inspection because my horn doesn't work. I have no idea how long it hasn't worked ...
    Dachristianman is offline Cadillac Owners Member
    Jun 2012
    46
    79
    Horn Inop
    My car failed our state inspection because my horn doesn't work. I have no idea how long it hasn't worked because I've only owned the car for a year.
    I checked my relay and from there, the horn works.
    I can set my alarm off, and the horn works from there, so I think I'm down to my steering column. Can anyone give me some guidance on what wires I should be testing in there? I found a block of 4, 2A fuses and all of them have power going to them except for the yellow wires which don't have power going to them. Is this the 2A fuse showing up on the wiring diagram? The wiring diagram I have doesn't show what color wire the horn wire is going into the steering column.
    Thanks in advance.
    Tom
    04 SRX
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Probably the horn button under the air bag. Pull the bag and check the contacts.
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: Horn Inop
    1Bad......I think he wants clarification on the wiring (and diagram) so he doesn't have to start pulling it apart unnecessarily.
    PJ
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: Horn Inop
    Here- and watch out for the yellow wires, usually SIR related.
    04 horn.pdf
    Been fixin' cars for 74 years
    Jun 2012
    46
    79
    Re: Horn Inop
    Thanks guys. But even from that .pdf, I can't tell what color the wire is under the horn pad. If I knew where that C202 was located, I could disconnect it and from there check the ground going to the horn switch.
    Also, how does the airbag come off? I don't mind pulling it if it's not hard to remove.
    Tom
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: Horn Inop
    C202 is a 40 pin connector at base of column. For bag removal you could make your own tool or maybe find at a parts store. Disconnect (-) battery cable 5min before working on SIR components.
    04 wheel.pdf
    Jun 2012
    46
    79
    Re: Horn Inop
    Thanks for all the replies. I got it fixed. A couple notes for those using the search engine in the future and find this post.
    Greeting from 2013! Here are a few tips.
    All of the trim under the steering column is easy to remove. Just pull off the phillips-head screws and the plastic comes off. Be aware of the 1 screw behind the hood-release handle. Also, the steel knee plate comes off with 2 10mm (?) bolts to allow access to a small fuse block that you'll need to check (details further down in this post).
    If you desire, you can remove your airbag with a #2 screwdriver. Make sure you disconnect the battery, and you can pull the airbag fuse located where your heels would be if you are sitting in the back seat on the passenger side. It's under the carpet below the leading edge of the seat. The #2 screwdriver is inserted in each of the 3 holes on the rear of the steering wheel. Turn the now inserted flat-head screwdriver 90 degrees and one edge of the cover will come off. Do that 3 times and the entire front of steering wheel comes off with the air bag intact. If it explodes, you did something really wrong. Note! Be sure to replace the fuse before you hook the battery back up as I imagine that the lack of power to the airbag would cause a hard fault in your airbag system. I'm not 100% sure about that, but unless you have money to burn, don't test my theory.
    The horn button ground wire is a black wire attached with a simple clip/plug to the metal structure inside the steering wheel. It uses the metal airbag guide pins to provide a ground when you slam down the horn button in anger in traffic. Normally, this informs the other driver of your anger through a series of reactions inside your SRX, but you're currently out of luck with this. Anyhow, the black wire goes into a plug also located inside the steering wheel and comes out the other side of the plug as a green wire that goes down the center of the steering column to a 2A fuse that is co-located with 4 other 2A fuses. If you pull this fuse out, you can use a wire to ground out the side of the fuse that goes to the horn relay located in the under-hood fuse box. By grounding that fuse out, you're providing a ground for the horn relay which then provides power down to your horns. If the horn still doesn't blow from grounding out that side of the fuse, good luck because your problem is located somewhere from that point forward.
    But before you take the airbag out, check to see if your steering column has a good ground. The entire steering column is grounded with the 4 13mm bolts securing it to the vehicle. If your steering column isn't grounded, the horn won't operate. Yes, all 4 bolts can be loose enough to cause the steering column to lose ground. So if you lose your steering column ground, just tighten the bolts a little until you get the ground back and your horn should blow.
    Have fun in whatever year you're in as time sure does fly doesn't it?
    T. Christopher
    Janisrick is offline Cadillac Owners Member
    Automobile(s): 2006 SRX V-8 AWD
    Sep 2013
    69
    9
    Re: Horn Inop
    Congrats on getting your horn working again! You never did mention what the problem was though. Can you share what you had to repair in order to get it working again.
    Jun 2012
    46
    79
    Re: Horn Inop
    The horn switch is grounded through the steering column. If the 4 bolts that connect the steering column to the vehicle come loose, you lose your ground and the horns won't work. That is what happened to mine. After extensive troubleshooting, I tightened the bolts and the horns started working again. I found it odd that all 4 bolts could get loose enough to cause the horn to lose it's ground, but they did.
  12. Remove Advertisements
