Transmission bypass valve removal due to "Hot Trans Idle Engine error"
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Like Tree1Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Transmission bypass valve removal due to "Hot Trans Idle Engine error" in Cadillac SRX / XT5 Forums; I have a 2004 srx V8 and I have just change my transmission oil. driving for only around 300km and ...
    royan97's Avatar
    royan97 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX - V8
    Aug 2010
    Doha, Qatar
    41
    42
    I have a 2004 srx V8 and I have just change my transmission oil. driving for only around 300km and I notice my transmission fluid life is down to 96%. Before I have read about the 2004 model having a bypass valve for the transmission line that was remove on the 2005 model because it was susceptible to getting stuck in the close possition. I have this car for 3 years already and have change the transmission oil twice already. I also read that the transmission cooler lines can be replace by the newer kind which does not require the bypass valve.
    Has anyone experience the process of replacing the transmission cooler lines. Is there a way to check if my transmission fluid is circulation properly or determine if my bypass valve is stuck in the close position.
    I don't know maybe I need to replace my transmission coolant first before replacing the transmission cooler lines. I also took a picture of what I think is the bypass valve.
    rabee likes this.
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    Re: Transmission bypass valve removal due to "Hot Trans Idle Engine error"
    Given the climate where you live, combined with the fact that the bypass valve was discontinued after 2004, I think the best thing to do is to remove the bypass valve and install the later transmission coolant lines.
    Bill
    royan97's Avatar
    Aug 2010
    Doha, Qatar
    41
    42
    Can any body provide me with the part number of the new coolant lines (upper and lower) without the bypass valve. The only dealer here seems clueless since I complain this already and they said everything was fine and just change my transmission oil and filter.
    SFVetteman's Avatar
    Jul 2011
    San Francisco
    1,116
    You should PM Chris the parts guy at Rippy Cadillac. He posts under the handle of "RippyPartsDept" and is an authorized vendor.
    Bill
    royan97's Avatar
    Aug 2010
    Doha, Qatar
    41
    42
    ACDELCO Part # 19129780
    HOSE,TRANS FLUID CLR Upper USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934-FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 ,11515757 & REMOVE THERM BYPASS VLV.
    * Stocked in outlying warehouse--shipping delayed up to 5 business days
    $18.00
    ACDELCO Part # 19129779
    HOSE,TRANS FLUID CLR LWR USE TOGETHER WITH 19129780 ,11515757 & REMOVE THERM BYPASS VLV.
    royan97's Avatar
    Aug 2010
    Doha, Qatar
    41
    42
    Transmission life update:
    June 28, 2013 - 96%
    July 28, 2013 - 70%
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    800
    I'm not sure of your ultimate intensions.... do you intend to remove/replace the existing bypass unit? Just waiting on the parts?
    Admittedly I'm flying blind as I've never seen the "innards" of the unit but most thermal bypasses I have seen have some type of bimetal element that covers or uncovers an opening to redirect flow. If you have access to a hoist and/or a trusted mechanic perhaps it would be worth while to remove and inspect the bypass valve to determine if it could be modified to eliminate the thermal element.
    royan97's Avatar
    Aug 2010
    Doha, Qatar
    41
    42
    I already got the new transmission lines without bypass valve. Just waiting for my oil life to reach 0%. Here it cost almost $300 US to change transmission oil and filter.
    June 28, 2013 - 96%
    July 28, 2013 - 70%
    August 28, 2013 - 60%
    Jan 2007
    800
    Assuming the apparent rapid depletion of oil life is related to a high fluid temperature aren't you risking damage to your transmission by waiting?
    DougC..'s Avatar
    DougC.. is offline Cadillac Owners Member
    Jun 2011
    39
    50
    Doesnt the life % come from miles driven? I mean, you dont think that its testing your fluid each time you start the car.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It works in a similar way to the OLM, it doesn't test the oil, it monitors several parameters (miles, RPM, temp... It should also go straight to zero if the fluid is overheated.
    rabee is offline Cadillac Owners Member
    Oct 2014
    47
    3
    hello"i clean all cooling fluid line"so radators""nd chang trans fluid filtter nd new fluid"" and stell my cadillac transmissons very hot""trans hot idle engine}this indcator stell on"after draiving 150 mils"" can i chang pypassvalve??please any one has idiaer"can tellme""thanks
    Tiger1106 is offline Cadillac Owners Fanatic
    Automobile(s): SRX'05 4.6L
    Jul 2014
    235
    Had a problem of trans overheating after driving at high speeds a couple of years ago. A change of the valve (about $40) solved the problem up to this day. Of course, I changed the fluid after that. Don't see the need to change pipes.
  16. #14
    Oct 2014
    47
    3
    what happen"after u cahnge pypass valve"??? please tell me""
  17. #15
    Jul 2014
    235
    It never overheated again.
  18. Remove Advertisements
