Brake fitting size
Results 1 to 6 of 6
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Brake fitting size in Cadillac SRX / XT5 Forums; Anyone know the size wrench I need to take the fitting off to remove the brake tubing,this is the hard ...
    orandaberg Guest
    Brake fitting size
    Anyone know the size wrench I need to take the fitting off to remove the brake tubing,this is the hard pipe from front to rear
    Thanks
    orandaberg Guest
    Re: Brake fitting size
    9/16"
    Thanks
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Bet it's not, unless we are in 1964 all of a sudden. Did you try a 14mm flare nut wench.
    orandaberg Guest
    yep its 9/16 thats what I needed to remove the fittings, just finished removing the lines both to the rear, the worst of the rust is where the lines fit into the brackets holding the lines together to the frame, however if GM used the right material there would be no rusted lines.
    14mm flare nut wrench? Is that a another word for open end wrench? and no 14 mm did not fit
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    A flare nut wrench is like a 6 point box wrench with a section removed so you can slip it on over the tubing...gives you the grip of the box wrench in situations where you would otherwise have to use an open end wrench.
    bill
    orandaberg Guest
    Now thats clever, I will use one to refit, and remove the other 3 needed
  9. Remove Advertisements
