Results 1 to 8 of 8
Thread: power steering quit all of a sudden
    brianw is offline Cadillac Owners Member
    Automobile(s): 2004 SRX AWD V8 - 2014 F-150 SCREW
    Dec 2010
    38
    66
    Question power steering quit all of a sudden
    My wife has a 2004 SRX, AWD, V8. Drove it yesterday and everything was fine. She got in it to leave this morning and the power steering is no longer working.
    What are my first areas to check? Fluid level, belt? No DTC codes at the moment that I'm aware of.
    Whiplash_89's Avatar
    Whiplash_89 is offline Cadillac Owners Fanatic
    Automobile(s): 04 SRX V8 AWD, 04 NSRT4
    Nov 2012
    Windsor, ON
    223
    Re: power steering quit all of a sudden
    Fluid, check for leaks as its a common issue.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,921
    No fluid you'd hear a screech. Check belt.
    Been fixin' cars for 74 years
  5. #4
    Dec 2010
    38
    66
    Just checked it out. Belt is in great condition, I couldn't see any cracks or anything in the belt and the fluid looks good too. Was at "hot" level and not darkened at all.
    Pump for sure?
  6. #5
    jsiddall is offline Cadillac Owners Fanatic
    Automobile(s): 09 SRX V8 AWD Sport, 06 STS V8
    Oct 2009
    Ottawa, Canada
    43
    159
    Any DIC messages? If there is a problem with the variable assist solenoid the steering will seem very stiff (like no assist) when in reality it just has less assist. Unfortunately it is more likely the rack than the pump.
  7. #6
    Dec 2010
    38
    66
    no codes. I have gotten the steering position sensor off and on a couple of times in the past though. It comes on then goes off after a day or two.
  8. #7
    Dec 2010
    38
    66
    Is there a way to isolate it and determine if its the steering pump or the rack & pinion?
  9. #8
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,921
    Dealers have a test tool to check pump pressures (>700 psi) that would determine that. I'm wondering if your work on the steering wheel position sensor is involved; can affect system. There is also a code (C type) in the ABS system that will disable the variable effort system.
  • You may not post replies
