V8 SRX Engine Fan stays on when car is off
Results 1 to 5 of 5
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, V8 SRX Engine Fan stays on when car is off in Cadillac SRX / XT5 Forums; The other day I noticed that the engine fan stayed on when I turned the car off in the driveway. ...
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,224
    The other day I noticed that the engine fan stayed on when I turned the car off in the driveway. While it was doing so, the temperature gauge was at about 75%. I'm fairly certain that it is usually dead center. Does that indicate that the coolant is end of life?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Coolant life determines its anti corrosive properties not it's cooking efficiency. Check the level is it low? Sounds like a stocky thermostat to me.
    Sep 2003
    NY
    1,224
    Re: V8 SRX Engine Fan stays on when car is off
    Where should the temp gauge be?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,803
    Center is normal. If coolant cap is not holding pressure, could be causing your problem. Some parts stores can check, but only about $5 to replace. If coolant is >4yrs., should replace. You can check w/a DMM. Neg. lead to Batt-, pos lead in coolant, should show about .5V or less if good.
    Been fixin' cars for 74 years
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    If you have V92 you have an extra water pump that from what I could figure out can continue to run after the engine is off so your cooling system keeps working after you shut off.
  8. Remove Advertisements
