Checking transmission temps while driving
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Checking transmission temps while driving in Cadillac SRX / XT5 Forums; So how do I get my transmission temperature while I drive? Scanner, Bluetooth dongle and app? I want to see ...
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    I want to see what my temps are while towing.
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    I've used a bluetooth and torque app and if I remember that is one of the parameters that isn't available
    Stillrollin is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX AWD V-6
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    Re: Checking transmission temps while driving
    I can't get a transmission temperature reading for my '08 SRX V6 with my Dashhawk, either.
    I've been told that the DIC will indicate too high a temperature reading, but have not a clue where it is getting the info.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,798
    There is a temp sensor in the valve body that is wired to the TCM.
    Been fixin' cars for 74 years
    Sep 2007
    2,621
    Is it a 0-5 signal?
    I guess if I know the range I can figure it out.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,798
    Looks like the TCM is internal to the transmission and connection to the ECM is by data link, so no way to tap into the signal. Why not an aftermarket gauge?
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    792
    contact http://www.aeroforcetech.com/
    I'm using one of their gauges on my 07 5 speed. Had to send it back a couple times but they were good to work with. I tried a scanguage II (www.scanguage.com) but could never get it to read trans. temp. Maybe they've updated the software. Might be worth an inquiry.
    orandaberg Guest
    I believe my aeroforce gauge was reading this, When I get home next week I am hooking it back up and will look if you do not already find out by then.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Nope, ScanGauge won't read transmission temps. For most units the sensor is a go-no go affair - temp exceeds some value depending on transmission model and the sensor does one or more things - sets a message, sounds a warning, or turns cooling fans to fast (Northstar FWD) - and the trip temp is 304 degrees F (from the GM service manual).
    Fluid temps of 225 are perfectly normal - and the new (2006) DEXRON-VI synthetic can run pretty hot -safely. In most vehicles the transmission cooler is in the return tank of the radiator, so it gets the benefit of the "cool" end of the radiator.
  12. Remove Advertisements
