Engine/transmission mounts
Results 1 to 2 of 2
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Engine/transmission mounts in Cadillac SRX / XT5 Forums; Have just had a reputable shop inform me that I need to replace the engine/transmission mounts on my '05 SRX ...
    niteryder is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX
    Aug 2005
    Houston, Texas
    21
    Have just had a reputable shop inform me that I need to replace the engine/transmission mounts on my '05 SRX (208K miles) It is V8/AWD. There is a slight rumble between 1200-1800 rpm with or without the A/C on. This occurs at rest or in motion. They have ruled out harmonic balancer and other internal issues. Is this diagnosis consistent with the experience of others?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Put your e brake on left foot on brake wheel blocks if you have them and rapidly press the gas up and down several times while having someone check your engine movement and lift I'd there is a lot of movement or you hear the noise pinpoint which one are bad and replace as necessary
