Bad Day
Results 1 to 13 of 13
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Bad Day in Cadillac SRX / XT5 Forums; In New york times, we are dealing with 90 degree weather. So on the way to work the car power ...
    Caddy Dave's Avatar
    Caddy Dave is offline Cadillac Owners Member
    Automobile(s): 04 srx V8 Northstar
    Jul 2012
    Bronx NY
    40
    61
    Bad Day
    In New york times, we are dealing with 90 degree weather. So on the way to work the car power shut down and on the screen it say (engine power reduce). So now when you start the car it shake like the car is miss firing. Is my car dead , or could this be a easy fix?
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,804
    Re: Bad Day
    Get your codes read and let us know; then we can help. Until then, it will be a bad day.
    Been fixin' cars for 74 years
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    329
    Re: Bad Day
    v6 or v8?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Some owners on here got that message for a throttle body issue another possibility is a major fault and the ecu picked it up in time. Get the dtcs and we can help you more
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Re: Bad Day
    Sort of like saying my leg is sore, what is it and can you fix it?
    Caddy Dave's Avatar
    Jul 2012
    Bronx NY
    40
    61
    Re: Bad Day
    Its a v8 and when i fine out the codes i will let ya'll know and thanks.
    Caddy Dave's Avatar
    Jul 2012
    Bronx NY
    40
    61
    Re: Bad Day
    Got the car back yesterday, they say it need a Mass air flow sensor, throttle body kit and a map sensor. If I get the parts, can I do it myself?
    Another thing do the 04 srx northstar v8 have a Idle Air Control Valve? and if it dose where it is located?
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,804
    Re: Bad Day
    That sounds like a lot of stuff went bad all at the same time, NOT. What were the code numbers so we can help.
    Sep 2007
    2,621
    Re: Bad Day
    Wow you need to find a repair shop not replace shop, that is brutal troubleshooting.
    Good thing they did not become doctors.
    You should be able to replace those parts on your own with some help from the forum, are you able to operate a volt meter and have some basic hand tools?
    Caddy Dave's Avatar
    Jul 2012
    Bronx NY
    40
    61
    Re: Bad Day
    The code that comes up now is P0174, sys too lean in bank 2.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,804
    Re: Bad Day
    If that's your only code, most likely a vacuum or exhaust leak (ahead of cat) on driver side. BUT, it should not have sent car into reduce power mode?
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: Bad Day
    Caddy Dave..........can you add "V8" in your profile under "Automobiles?" It would have helped you initially get some help from others in this thread and in the others in which you have participated and asked questions about your SRX.
    PJ
    Jschuch is offline Cadillac Owners Member
    Jul 2004
    13
    I just replyed to another post with this similar code.171 and 174. For me it was a leak on the PVC lines. It was the "dirty side" see the schematics on this forum. When i tried to take the pvc lines off the rubber fittings crumbled in my hands. Completely the source of the vacuum leak. I see this as a common issue with this era northstar. It drove me nuts and i spent a lot on mass air flow sensors etc. Please check out both your pvc hoses. It can be a cheaper fix than all those other diagnosis. (I like the comments to find a repair shop not a replace shop). Once i replaced these leaking hoses, and yes my engine ran rough, everything got better. No damn codes, smooth running engine. I hope this helps.
  16. Remove Advertisements
