2008 SRX starting problem ONLY after getting fuel
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2008 SRX starting problem ONLY after getting fuel in Cadillac SRX / XT5 Forums; The problem started about 1 month ago: the engine acted like it was flooded; i had to start the car ...
    winddyy is offline Cadillac Owners Member
    Automobile(s): deville
    Aug 2011
    3
    The problem started about 1 month ago: the engine acted like it was flooded; i had to start the car 4-5 times before it will start up. After that, the car starts normally and runs great until the next fuel fill-up. I have tried different gas companied and also used fuel treatment but no luck fixing it.
    Does anyone else have this problem? Any suggestions?
    Thanks in advance for any help.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Sounds like fuel pressure regulator. Pull the vac line off turn key on and see if fuel drips from it.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,799
    Re: 2008 SRX starting problem ONLY after getting fuel
    Check for DTCs even though the MIL light isn't on. Maybe a new gas cap? Check all engine grounds you can find incl. battery neg. cable.
    Been fixin' cars for 74 years
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    I vote for gas cap.
    drod777 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6
    Oct 2012
    24
    56
    Have had the same problem and now having to replace the solenoids. replaced the gas cap and that did not help had #P0446 DTC
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,000
    Another area could be a clogged fuel filter, especially if the problem gets worse over time and you start getting hesitation on acceleration as well.
    Sackett is offline Cadillac Owners Member
    Apr 2012
    San Angelo, TX
    26
    Had a similar issue last year on our '08 but it wasn't after fill up. It had been sitting for a bit and went to start it. Wouldn't start and had bad fuel smell. Finally got it started, and it ran rough for a minute until it cleared up. I guessed some kind of weird vapor lock issue, hasn't happened since.
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by Sackett View Post
    Hello Sackett,
    I am happy to hear your vehicle hasn't had the start up issue recently. I hope you are enjoying driving your SRX around!
    Regards,
    Laura M.
    Quote Originally Posted by winddyy View Post
    Hello winddyy,
    I am sorry your vehicle is having start up issues. I see other members on this forum have given good insight on the situation and possible solutions to it. If you want to discuss your concerns or issues further, please reach out to us via private message.
    Sincerely,
    Laura M.
    Aug 2011
    3
    It was the Evap Solenoids; replaced it and no problem since. Thanks for all the inputs/advices. This forum rocks.
  12. Remove Advertisements
