P0446 ????
Results 1 to 14 of 14
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, P0446 ???? in Cadillac SRX / XT5 Forums; Well I just realized my engine light never came on when I would start up my SRX. So I had ...
    drod777 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6
    Oct 2012
    24
    56
    QuestionP0446 ????
    Well I just realized my engine light never came on when I would start up my SRX. So I had asked auto parts store to read my car and constantly argued about if it does not come on there is nothing he can do. Well soon to find out this code came up and the Guy was in shock there was a code!! So he told me what the code # but did not explain what it is.......
    Can someone help me out
    Thanks!
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Re: P0446 ????
    Bing it.
    Then search here for the answer, maybe a purge solenoid.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,825
    Re: P0446 ????
    From the SM-
    "This DTC tests the evaporative emission (EVAP) system for a restricted or blocked EVAP vent path. The control module commands the EVAP canister purge solenoid Open and the EVAP canister vent solenoid Closed. This allows vacuum to be applied to the EVAP system. Once a calibrated vacuum level has been reached, the control module commands the EVAP canister purge solenoid Closed and the EVAP canister vent solenoid Open. The control module monitors the fuel tank pressure (FTP) sensor for a decrease in vacuum. If the vacuum does not decrease to near 0 inches H2O in a calibrated time, this DTC sets."
    Advise if you want DIY help.
    Been fixin' cars for 74 years
    Oct 2012
    24
    56
    Re: P0446 ????
    Quote Originally Posted by glake89 View Post
    From the SM-
    Ok thanks very much, do I just need to change Canister Vent Valve Solenoid that's near the gas tank or the one on the engine
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,825
    Re: P0446 ????
    Not really that simple and those 2 parts aren't the only ones that can go bad. You can do most of the tests in the diagnostic by using other means than the tech II tool that they request. If you are serious, PM your e mail and I'll PDF the diagnostic.
    Oct 2012
    24
    56
    Re: P0446 ????
    Well just spoke to an GM mechanic that is local and said it runs about $1300 to have it fixed for the front and rear
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,825
    Re: P0446 ????
    You'll know why when you get the diagnostic.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,825
    Re: P0446 ????
    Gave some extra thought to this. Since you don't have codes for fuel tank pressure, the vent system is working- just not fast enough for the little chinamen with the stop watches in the ECM. If you're not having drive-ability problems, not to worry.
    Oct 2012
    24
    56
    Re: P0446 ????
    Ok so what do you think the issue is??
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,825
    Re: P0446 ????
    I would guess a partial obstruction of the vent line. Since the DTC is based on how long it takes for the venting to reduce vacuum to near zero, the system is just working slow. If it didn't work at all you would get a DTC for high fuel tank vacuum.
    Oct 2012
    24
    56
    Re: P0446 ????
    Do you know if there are any products that can clear the obstruction or add something to the gas tank?
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,825
    Re: P0446 ????
    It is most likely a mechanical (physical) obstruction.
    Sackett is offline Cadillac Owners Member
    Automobile(s): 2008 SRX
    Apr 2012
    San Angelo, TX
    26
    Quote Originally Posted by conedoctor View Post
    Bing it.
    I think that's the first time I've seen that phrase.
  16. #14
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: P0446 ????
    CONE owns shares of Microsoft...... :-) PJ
  17. Remove Advertisements
