removing ignition cylinder
Results 1 to 5 of 5
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, removing ignition cylinder in Cadillac SRX / XT5 Forums; been trying to remove the ignition cylider so I could remove the column cover.I keep poking a small awl into ...
    kilrcady is offline Cadillac Owners Member
    Automobile(s): 2007 srx 1977 coupe deville
    Jan 2011
    22
    been trying to remove the ignition cylider so I could remove the column cover.I keep poking a small awl into the small hole underneath the ignition and it does nothing.I cant get it out.What am I doing wrong?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,801
    Re: removing ignition cylinder
    From the SM-
    "Disconnect the negative battery cable.
    Turn the ignition switch to the START position.
    Insert the awl into the lower steering column trim cover access hole.
    Press in the release button using the awl."
    "Release the ignition switch to the RUN position.
    Remove the ignition lock cylinder."
    That should do it.
    Been fixin' cars for 74 years
    Jan 2011
    22
    Thanks will try this
    bhodge is offline Cadillac Owners Member
    Automobile(s): 2007 CTS
    Oct 2013
    Austin, TX
    38
    5
    Hi,
    I was trying this as well but after pressing the release button using an awl, I removed pressure from the button before releasing the ignition. As a result the ignition cylinder moved past start and is now stuck. If the release button is not pushed, I cannot rotate the ignition at all, clockwise or counter. If I push the release button, it pops out, maybe 1/4" to 1/2" at the most and only allows me to rotate clockwise about a quarter turn but does not allow me to pull out the cylinder.
    So now I'm at point where I can't get the key out and the ignition cylinder is stuck in a position slightly past start so I can't even start the car. Does anyone have any ideas on how to get my cylinder back in its proper position? I am about to rip off the bottom cover so I can get access to the switch but not even sure what to do after that. I would think that this might be a semi-regular issue as I could see it easily happening so hopefully there is an easy fix. Any help would be greatly appreciated. Thanks in advance.
    Oct 2013
    Austin, TX
    38
    5
    Apologies, I posted this in the wrong forum. I have created a new post in the CTS first gen section where it belongs here
  8. Remove Advertisements
