quick question about firewall
Results 1 to 4 of 4
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, quick question about firewall in Cadillac SRX / XT5 Forums; Trying to find a good sized hole on a 09 srx 4wd on the passenger side firewall near the battery. ...
    T3mpest is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2007
    11
    Trying to find a good sized hole on a 09 srx 4wd on the passenger side firewall near the battery. Anyone know of a good whole or where I should be able to drill one without alot of issue. Looking to get fit a run of 0 gauge wire.
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Best place is to check your local installers
    orandaberg Guest
    Infront of the brake pedal is a rubber boot on the firewall. Its where the main wire harness runs. But to access it from the outside you have to loosen the coolant resovoir to get your arm in there. Best way is to push the wire through is from the inside an out
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    37
    144
    Quote Originally Posted by orandaberg
    I used this method to run cable for my brake controller. Once you push the wire through liberally from the inside, you might be able to grab it with a long set of pliers.(or similar)
  7. Remove Advertisements
