Need a wiring diagram from SM.
Results 1 to 13 of 13
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Need a wiring diagram from SM. in Cadillac SRX / XT5 Forums; Hello, Well I can't pull up the SM right now and need a wiring diagram to finish testing something, I ...
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    I need the pin out for code K14, I think it is the front left headlight harness, it is the same harness that feeds the dual push fans.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,804
    Re: Need a wiring diagram from SM.
    The diagrams aren't done that way. Need the item you're testing e.g. headlight
    Been fixin' cars for 74 years
    Sep 2007
    2,621
    Hmm, ok.
    I am adding the K14 air quality sensor, I found an old printout of the pin out.
    The wires for it travel out to the front of the car in the headlight harness, so I need to backtrack to where that harness plugs in underhood and see how many wires the non K14 car.
    So I guess I need to look up the harness routing not so much a wiring diagram.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,804
    Found this-
    "The air quality sensor recognizes carbon monoxide but is not designed as a safety feature to protect you from carbon monoxide. The air quality sensor is designed to limit your exposure to gasoline exhaust fumes and or diesel exhaust fumes that could enter into the passenger compartment from nearby vehicles for a limited amount of time.
    The HVAC control module monitors the outside air quality while in AUTO mode via the air quality sensor assembly. You can activate the air quality sensor on your vehicle, if equipped, by pressing the Auto button on the HVAC module. The air quality sensor is a 5-wire sensor, 1 ignition voltage circuit, 2 ground circuit, and 2 control circuits. There are 2 sensors inside the air quality sensor assembly. A hydro carbon (HC) sensor that is used for detecting gasoline exhaust fumes and a Nox sensor that is used for detecting nitrous oxide, diesel exhaust fumes. The HVAC control module outputs a 5-volt signal on the HC and Nox control circuits and operates in a range between 0-5 volts.'
    There's more if you need it.
    There are 30 harness routing drawings and they're not real clear. Maybe this will help=
    airq.pdf
    Let me know what else you need. It's great to be retired!
    orandaberg Guest
    PIN 1 YE CIRCUIT NUM. 61 low reference
    PIN 2 PU/WH CIRCUIT NUM. 5203 AIR QUALITY SENSOR SIGNAL
    PIN 3 PK CIRCUIT NUM. 1439 IGN 1 VLT.
    PIN 4 L-GN/WH CIRCUIT NUM.6845 AIR QUAL. NOX SENSOR SIGNAL
    PIN 5 N/A
    PIN 6 BLK CIRCUIT NUM. 250 GRND.
    Sep 2007
    2,621
    Ok that is the drawing I have as well, so I could wire from each of the modules to the sensor but I was looking to find out where the K14 harness would plug into under the hood and see how many of the K14 wires are there and just not used.
    From the look of the drawing they plug in by the fusebox on the right side, I will start there.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,804
    Yes, connector X116 looks to be under the fuse block.
    Sep 2007
    2,621
    Sweet, I will have a look and see if GM did the wiring for me.
    Now I have the pins and what they do, is there a picture of the connector just to make sure I get them on the right pins.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,804
    good enough?
    Sep 2007
    2,621
    That should work awesome.
    But where is pin 2 lol
    orandaberg Guest
    Quote Originally Posted by conedoctor View Post
    Your kidding right?
    Sep 2007
    2,621
    Ok so with the help of my 7 year old ( I am colourblind, not so fun for this in low light with dirty wires) I think I have it figured out for the most part.
    So now the #61 yellow wire coming out of the bottom, it goes into a complete physical splice, what would that look like?
    I also want to know what an option breakout looks like, this is where the AQS ties into the air temp sensor, do I just cut and spice so it looks like the diagram?
    For lack of a better word is the option breakout a tee?
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,804
    I would try it with a jumper using alligator clips first, then solder and wrap if it works.
  16. Remove Advertisements
