Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Knocking & Shaking at Idle - Rod Knock? Something Else?
    SRT ACE's Avatar
    SRT ACE is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    82
    Hello all - I'm in need of some help. The problem vehicle is my wife's 2004 SRX V6 AWD w/ 132k miles.
    Recently we began to experience a shake/shudder followed by knocking noise at idle. Generally this would happen only after the car was warm and after coming to a complete stop. It is intermittent, and nothing is noticeable while driving.
    Just today I took the car for a ~5 mile, stop and go, drive to reproduce the problem and capture it on video. For the first 4.98 miles, nothing. Just as I was pulling back into my wife's work parking lot ready to give up, the problem reared its ugly head. I had come to a complete stop and the car began the tell tale sign of the shaking, followed by the knocking. It continued as I moseyed around the parking lot for a bit and captured videos (see below). It stopped and was silent for the last 50 feet before parking, and while idling in the parking space.
    The car is the classic oil consumer, including a leak from the front engine cover. Before driving today I checked the oil and added 1 qt to bring it back up to full.
    There are no CELs.
    Without leading the witnesses any further, here are the videos:
    From the: driver's seat & driver's front wheel well
    From the: top of engine bay
    Happy to answer questions and provide more information. Thanks for any insight.
    -ace
    Sep 2007
    Wilmington, NC
    13,969
    Re: Knocking & Shaking at Idle - Rod Knock? Something Else?
    have you checked the oil level with the dipstick lately?
    SRT ACE's Avatar
    Aug 2008
    82
    Chris, thanks for the super quick reply. From my OP, "The car is the classic oil consumer, including a leak from the front engine cover. Before driving today I checked the oil and added 1 qt to bring it back up to full."
    It is about due for a change, so I'm tempted to check & inspect the discharged oil and filter for metal filings or other symptoms...
    -ace
    Edit: I'm pretty good about checking the oil level, but over time it has gotten lower than I'd like on several occasions.
  5. #4
    Sep 2007
    Wilmington, NC
    13,969
    Your timing chains are probablys stretched a bit ... that's the end result of running low on oil or without oil
    the timing cover's got to come off to confirm but it's the most likely cause of that symptom
  6. #5
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    That's new to me if it was rod knock typically that doesn't just go away. Another scenario i can think of would deal with collapsing timing chain tensioners or something blocking the oil passages. Check the oil filter for any shavings but its definitely not something to be driving on. Doesn't look like the harmonic balance coming apart its turning smooth. Timing chain hitting the cover. I would love to be there to put a stethoscope on it to further tell. I would imagine some codes though cause mine had codes for a stretched chain bit i have a startup rattle and no codes.
  7. #6
    Sep 2007
    Wilmington, NC
    13,969
    the chain stretch will throw codes but not initially ... usually only shortly before catastrophic failure
  8. #7
    SRT ACE's Avatar
    Aug 2008
    82
    Strangely, it only seems to happen once warm and NOT at startup. It seems most other chain related issues have been at startup.
    What is the shop time listed to pull the chain cover for inspection? I'm thinking this is my next step.
    Also, I'm guessing that this condition, although intermittent, is not something that should be driven on. Sounds like 'repnatl' agrees...
    -ace
  9. #8
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Oil is cold and you have more pressure so maybe a pressure related problem, put a gauge on it and see what your oil pressure is. Maybe the pump is unhappy from being low once or twice.
  10. #9
    Oct 2012
    975
    Quote Originally Posted by SRT ACE View Post
    -ace
    Think the partial teardown time is 7-8 hours i paid $800 for them to remove the valve covers intakes and everything including the cover all the way down to the chains still installed.
  11. #10
    SRT ACE's Avatar
    Aug 2008
    82
    Thanks for all the input thus far. I've made arrangements to have it off the road until at least Friday.
    If an oil pump/pressure issue, wouldn't the sensor signal a dummy light? Could the sensor be bad? How about the thread size for the sensor (for the pressure test)?
    How does the shake/shudder that typically proceeds the knock tie in?
    For the next steps, in no particular order, I may:
    -dealer trip - diagnostic trip to the local dealer, not cheap, but expert knowledge
    -oil change (oil & filter inspection) - cheap, low hours, insightful (?)
    -oil pressure test - would need to pick up a test kit, but cheap, low hours, insightful (?)
    -partial teardown - not necessarily costly (if I do myself), but a lot of time
    Anyone inclined to steer me one way or the other? So, nobody seems to think it's rod knock?
    So, I couldn't sit still tonight and decided to quickly check the oil filter. Pictures:
    There did not appear to be any metal filings or sludge. Where does this take us?
  12. #11
    SRT ACE's Avatar
    Aug 2008
    82
    Took a video today on 'cold' startup. It was probably mid 60s. Can anyone who's had timing chain issues pick up on anything?
    Video of 'cold' startup
  13. #12
    The Wrench is offline Cadillac Owners Enthusiast
    Automobile(s): '08 SRX V6
    Oct 2007
    Dallas
    542
    Well, it's definitely not a rod or crank bearing knocking, or anything in the valve train; the sound is not rythmic, it's more random like a clattering. Sounds like an accessory driven by the fan belt in the cold video. Could be a timing chain slapping against the housing in the warm video, or a water pump.
    I recently had an alternator go bad on my Mercedes, and it shook the engine pretty hard - weird.
    Check the charge voltage gauge just to be sure.
    1. Pull the fan belt and check all the accessories by spinning them by hand. Then crank it up cold for a few seconds without the belts on, and see if the noise goes away; won't hurt it to run for a little bit.
    2. Or, buy a mechanic's stethescope for about $6 and probe all the accessories, then probe the front cover and timing chain area when it's making the warm knock.
    If you can better isolate the location you can narrow down the trouble-shooting.
    from the sounds, my guesses would be: bad water pump impeller, bad idler pulley, bad internal timing chain rail. But the missing engine rules out the first two probably.
    DG
  14. #13
    SRT ACE's Avatar
    Aug 2008
    82
    Quote Originally Posted by The Wrench View Post
    DG
    Thanks for chiming in, DG. Do I understand correctly that you think there is a secondary issue on top of the knocking sound? It sounds like The cold video was taken while the car was still warming up (i.e. higher idle). I have another video, (HERE, taken just after the engine lowered to its normal idle speed. Don't know if that helps. For what it's worth, before today I had never noticed the chirp heard in the latest video.
    I plan to pick up a stethoscope tomorrow and will report back.
    Does our car throw codes but not throw CELs? I can drive (5 mins) to AutoZone to get them pulled if so...
    One other thing. A friend of mine suggests it might be the torque converter and flex plate bolts coming loose. Is this possible? Thoughts?
  15. #14
    Oct 2012
    975
    Check all pulleys and tensioners and also the crank pulley. Sounds like one of those failing especially all that rust at the crank would be dried bearing grease gone
  16. #15
    SRT ACE's Avatar
    Aug 2008
    82
    Couples days later I'm finally reporting back (weather, head cold, etc kept me from doing any work). Bought the cheapo stethoscope from HF. It's my first time using one, but it would appear that the knocking sound is NOT coming from inside the front engine cover. Rather, the loudest two spots were directly on the power steering pump and the adjacent tensioning pulley. Using drinking straws (I know, real safe) I removed the remaining fluid from the power steering pump reservoir:
    **edit - removed picture as doesn't apply to this problem**
    It was only a couple ounces and looked very dark, burnt. For what it's worth, I doubt it's ever been changed. Could a failing power steering pump cause my symptoms? Or am I hearing a noise from behind the engine cover coming through the pump?
    I would try running it without the belts on, but I can't reliably reproduce the sound. I.e. I drove it for 10 minutes this morning - didn't make the noise once until I pulled into the driveway. I then drove it again for another 5 minutes - nothing until I pulled back into the driveway.
    Also, I was able to make the noise go away but putting the car into neutral and revving a little bit. The knock would go away, it would settle back down to idle RPMs and the knock was nowhere to be heard.
    Last edited by SRT ACE; 05-19-13 at 10:06 PM. Reason: removed picture - doesn't apply to knock
  • You may not post replies
