squealing belts
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, squealing belts in Cadillac SRX / XT5 Forums; The belts were changed and now the main belt squeals like a bangi. They sprayed belt anti noise but it ...
    orandaberg Guest
    The belts were changed and now the main belt squeals like a bangi. They sprayed belt anti noise but it just comes back. Any ideas. Still in garage. They said if it does not stop they nay have to out the old belt on. Need advice ASAP
    The squeal goes away when turning the wheels hard right and left
    The noise is comming from the power steering pump. It must have air in it from changing the hose?
    Followed the SM instructions fir bleeding air from PS system. All ok now
    Whiplash_89's Avatar
    Whiplash_89 is offline Cadillac Owners Fanatic
    Automobile(s): 04 SRX V8 AWD, 04 NSRT4
    Nov 2012
    Windsor, ON
    223
    Re: squealing belts
    I dont think air in the system would cause the belt to sqeal. Maybe they werent installed properly? Too tight or too loose.
    orandaberg Guest
    It has a auto tensioner nothing to adjust maually. The sound is back weird part is you spray the belt and the noise goes away till it dries. Follow SM procedure for bleeding air and it goes away. Need to go back and try the SM bleed routine agian.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,947
    Re: squealing belts
    If you can find it, add some Lucas Power Steering oil. Squealing may be bad tensioner. Try a drop of oil on its bearing.
    Been fixin' cars for 74 years
    orandaberg Guest
    Re: squealing belts
    No Access now, all is back on! However I did follow the SM bleeding air sequence and it was quiet as a mouse after we fired it up, then we shut it down and put on the underbelly shield and wheels, sat for a while, lowered the car and started it and the noise came back, I assume if it was a bearing the noise would of stayed even after the bleed sequence?
    Incidentally it was the easier bleed where we pumped the brakes 15 times and turn the wheel fully 12 times.
    We will try again in the morning but any more advice is appreciated.
    I pray its not a bad tensioner, then it has to all come back out!!!!!!!!!!!!!!!1
    Power Steering System Bleeding
    Important:
    • Use clean, new power steering fluid type only. See the Maintenance and Lubrication subsection for fluid specifications. Refer to Fluid and Lubricant Recommendations.
    • Hoses touching the frame, body or engine may cause system noise. Verify that the hoses do not touch any other part of the vehicle.
    • Loose connections may not leak, but could allow air into the steering system. Verify that all hose connections are tight.
    Important: Power steering fluid level must be maintained throughout bleed procedure.
    Fill pump reservoir with fluid to minimum system level, FULL COLD level, or middle of hash mark on cap stick fluid level indicator.
    Important: With hydro-boost only, the oil level will appear falsely high if the hydro-boost accumulator is not fully charged. Do not apply the brake pedal with the engine OFF. This will discharge the hydro-boost accumulator.
    If equipped with hydro-boost, fully charge the hydro-boost accumulator using the following procedure:
    2.1. Start the engine.
    2.2. Firmly apply the brake pedal 10-15 times.
    2.3. Turn the engine OFF.
    Raise the vehicle until the front wheels are off the ground. Refer to Lifting and Jacking the Vehicle.
    Key on engine OFF, turn the steering wheel from stop to stop 12 times.
    Vehicles equipped with hydro-boost systems or longer length power steering hoses may require turns up to 15 to 20 stop to stops.
    Verify power steering fluid level per operating specification. Refer to Checking and Adding Power Steering Fluid.
    Start the engine. Rotate steering wheel from left to right. Check for sign of cavitation or fluid aeration (pump noise/whining).
    Verify the fluid level. Repeat the bleed procedure, if necessary.
    orandaberg Guest
    Re: squealing belts
    How do I know if I have hydro-boost ?
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    Re: squealing belts
    Try Google
    TimRSRX777 is offline Cadillac Owners Fanatic
    Automobile(s): SRX
    Feb 2013
    126
    Re: squealing belts
    Why would squealing belts be symptom of air being in the system? My medium educated guess would be belt tightness either too loose or too tight. which would lead me to suspect the tensioner? Who do you have diagnosing and working on your vehicle? Did you try glake89's suggestion? Sounds to me like you eliminated that even before checking it as a possibility, no wonder you are having issues. Ignoring well meaning suggestions is something thats not exactly wise.
    orandaberg Guest
    Re: squealing belts
    I guess this is what it may look like, but I do not see it in the SM?
    http://www.amazon.com/Power-Brake-Hy.../dp/B00BMVJYLC
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,622
    Re: squealing belts
    We don't have hydroboost, it uses PS pressure instead of engine vacuum.
    Wrong belt maybe.
    When you do lots of steering the belt heats up and stops slipping, I would say the belt is too long or the auto tensioner is not up to full tension.
    orandaberg Guest
    Re: squealing belts
    So actually there is no bleed sequence if you do not have hydro boost, or is it the same sequence, because doing the sequence made the noise go away, so we thought in the morning we would do it again, if it does not work I guess its to remove the resovoir an look at the tensioner
    Quote Originally Posted by TimRSRX777 View Post
    Because we replaced a power steering hose and lost fluid
    Sep 2007
    2,622
    Re: squealing belts
    Turn left then right to bleed, the noise went away because the extra heat in the belt made it stick better, the load on the pump caused more friction on the belt, I would think.
    All of my Talons had the same issue and as soon as the belt would heat up it was fine.
    orandaberg Guest
    Re: squealing belts
    I did drive it for 45 mins an it never went away, so tomorrow if anything we will put the old belt on for a try.
  16. #14
    Nov 2012
    Windsor, ON
    223
    Re: squealing belts
    Quote Originally Posted by conedoctor View Post
    I used to have a talon too, 95 TSi AWD. You?
  17. #15
    Sep 2007
    2,622
    Re: squealing belts
    92 TSi AWD
    94 TSi AWD
    93 TSi AWD
    90 DL
    91 TSi
    93 Laser RS AWD
    93 DL
    97 TSi AWD
    Ya I have issues, good race cars and the 4G63 is one of the best 4 cylinders ever made.
  18. Remove Advertisements
