No oil on dipstick - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 35
Like Tree2Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, No oil on dipstick in Cadillac SRX / XT5 Forums; Originally Posted by Sackett Yah. How often are you guys changing oil? When the dummy warning tells you? By miles? ...
  1. #16
    Stillrollin is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX AWD V-6
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    Re: No oil on dipstick
    Quote Originally Posted by Sackett View Post
    Yah. How often are you guys changing oil? When the dummy warning tells you? By miles? Other?
    Bingo! I haven't had a lot of oil consumption on my '08 SRX V6 in the 25,000 miles I have driven it since buying it used in early 2011.
    Of course, I make it a point to check the oil level once per week and note the level after a oil change. I made the decision to NOT follow
    the oil life "suggestions" the DIC sends, even before I bought the car since I made the decision to limit miles between changes to 4500
    on my '07 Trailblazer SS which also had an overly optimistic view of oil life usefulness.
    I consider this engine to be "adequate" as a power plant for a vehicle weighing 4500 pounds or so.
    Do I think it is a good replacement for the "ancient" cast iron 3.8 liter turbocharged V6? NO!
  2. #17
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Is no level sensor for the 3.6
  3. #18
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    The oil LIFE monitor is actually very accurate and scientifically proven. Oil LEVEL is a different thing altogether.
  5. #19
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    Oh yes! This is particularly true if you don't drive your vehicles hard.
    I drive mine like I have stolen them and in the SRX's case, my experience has shown that it will consume oil if driven
    very far or often above 3000 rpms in mountainous terrain.
  6. #20
    newsrxowner is offline Cadillac Owners Member
    Automobile(s): 2006 SRX 2001 Deville
    Aug 2010
    Wisconsin
    93
    Quote Originally Posted by Stillrollin
    I go by the oil life indicator. I put about 400 miles a week on the car and I have found it does a good job. Now talk about oil consumption I am adding about 1/2 quart of mobile one every 1000 miles or so which is better then my wife's 2001 deville which is 2 quarts every 1000. Now some talked about the low oil indicator in the 3.6 or lack there of. The deville has a N* in it and if it does get too low the dummy indicator comes on. Not so on the 3.6. It would be nice if it had one.
  7. #21
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,837
    SM says that V6 has an oil level sensor. Threads into pan from bottom.
    Been fixin' cars for 74 years
  8. #22
    2broke4this is offline Cadillac Owners Member
    Automobile(s): 2005 SRX V6 RWD
    Apr 2013
    Alexandria, VA
    33
    15
    Quote Originally Posted by Stillrollin View Post
    I've only had mine for a month and a half, but there certainly seems to be something with the mountains... or the highway... or both. I drove mine to Nashville and back last weekend (about 1300 miles), and it chugged through 3.5 quarts! That said, it poured smoke out the exhaust on the way home, so I'm thinking there's something a little out of the ordinary going on! Dealership marked the dipstick this week and are having me drive it to do a consumption test. I guess my log of oil addition and the fact that I haven't even put 2k miles on it isn't good enough! I don't understand how a car that seems to be such a mess still seems to run and drive so darn well!
  9. #23
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Sackett.....were these the same guys who changed the oil the time before the level was low? Maybe these oil change guys did not replace the spent oil with the right amount. That happened to me, but I happened to check the motor oil level myself about an hour later. Two quarts low!!!!
    I do not mean to sound disrespectful. But the comments in this thread demonstrate a serios misunderstanding of the oil life monitor, the oil level, and the oil pressure......the oil life monitor is indeed accurate as was stated, the level can only be measured on the dipstick, and if the low oil pressure is present you are already in deep doo doo.
  10. #24
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    I ALWAYS check the oil level in my SRX after hang the oil changed as soon as I get a cool down in my garage. In this way I KNOW what the proper levee should be the NEXT time I check it. At the same time,I also ALWAYS check the torque setting on my wheel lug nuts any time they are removed for any reason.
    I have found some service techs use a "preset" air wrench to tighten the nuts and have had at times needed to put a three foot pipe on a 1/2" breaker bar to get them loose. Of course this is ALWAYS the last time I ever use that shop.
    Regarding low oil pressure, GM considers 25 psi at idle to be sufficient oil pressure.
    I personally don't agree with this assumption and consider it to be contributory to the stretched timing chains and worn out sprockets that others have experienced. I also plan to continue to use my own mileage standards which are less than that which the oil life monitor suggests because I KNOW that driving extended periods of time over 3000 rpms will cause the little piggy to consume oil.
  11. #25
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    800
    Quote Originally Posted by glake89 View Post
    Not sure when but this feature was deleted. It's not on my 07. The same with the 03 Envoy. Early 02's had the sensor but wasn't carried over into the 2nd model year.
    Wonder if it just didn't work and caused a liability issue.... any case not a substitute for looking under the hood and checking via the dipstick.
  12. #26
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,695
    Quote Originally Posted by 2broke4this View Post
    Hi 2broke4this,
    I am sorry your vehicle seems to be experiencing an oil consumption issue. Please keep us posted on this issue and if you would like to discuss anything or have other questions, reach out to us!
    Sincerely,
    Laura M.
  13. #27
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Some people confuse the OLM with oil level, they have nothing to do with each other.
    The OLM has not idea your oil level, I would assume it assumes the pan is full, the OLM will however change based on oil temp so it would speed up a bit based on high oil temp from low oil but not enough to keep up with checking the oil.
    If your engine is not using oil then why not use the OLM?
    I too at times have a hard time trusting in engineering but until Scully and Fox tell me the OLM is crap I will stick with it, assuming I have the amount of oil the system thinks I do.
  14. #28
    Feb 2010
    New England
    2,005
    STILLROLLIN........if you drive for extended periods of time over 3,000 rpm, you may use more motor oil. But for sure you will use more $$$ paying for speeding tickets. :-) PJ
  15. #29
    Apr 2013
    Alexandria, VA
    33
    15
    Quote Originally Posted by Cadillac Cust Svc View Post
    Hi 2broke4this,
    Sincerely,
    Laura M.
    Laura,
    Thanks for reaching out. At this point, I can't REALLY complain about how the dealership is handling the situation (although I suppose I did whine a little bit). I know they need to do a more accurate measurement. I bought the car used at a Ford dealership, so I have no real room to get upset. I mean, I'll be upset if they don't take care of it, but I really have no reason to expect them not to treat me right. I didn't really intend to jack this thread, but I suppose it's gone all over the place already! I'll start my own thread when I have more information. I've only had a chance to put about 50 miles on it since I got it back, I need to find a reason to go drive it somewhere and show them what its using. Thanks again.
    -Carl
  16. #30
    Mar 2010
    Detroit, USA
    12,695
    Laura,
    -Carl
    Hi Carl,
    Thanks for the response and keeping me updated on this concern. Continue to share your progress and updates, and if I need to help assist you in the future, I am more than happy to do so!
    Sincerely,
    Laura M.
  17. Remove Advertisements
