2005 Low Beam fuse allways melt (20a) right side
Results 1 to 5 of 5
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2005 Low Beam fuse allways melt (20a) right side in Cadillac SRX / XT5 Forums; Hi everybody have somebody an idea, what I can check? first: My right side low beam fuse allways melt. I ...
    pilot188's Avatar
    pilot188 is offline Cadillac Owners Member
    Aug 2011
    56
    94
    Hi everybody
    first:
    My right side low beam fuse allways melt. I replace the HID Bulb allready. High beam, turn light etc. are allready working
    second:
    I buy a used head lamp, but the connector of the 2005 -2007 is different to the later series
    So I have two questions
    1) which parts must be replaced to cover the melt of the fuse and where I can get this?
    2) Is there a possibility to convert the connector of a 2005 SRX to fit on the head light from the later series?
    Hope, somebody can help
    Uwe
    pilot188's Avatar
    Aug 2011
    56
    94
    Re: 2005 Low Beam fuse allways melt (20a) right side
    Only possible causes for my understanding
    Ballast and cable between beamer and ballast
    does any valeo lad5g (12 pin) ballast fit or is there a different version for cadillac?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,801
    If the right side fuse keeps blowing, either the ballast is bad or you have a short to ground in the wire. Unplug the ballast and put in a new fuse. If it doesn't blow, the ballast is bad.
    Been fixin' cars for 74 years
    pilot188's Avatar
    Aug 2011
    56
    94
    When I unplug the head lamp, the fuse don't blow away
    So for me, it sounds like the ballast.
    Does any valeo lad5g (12 Pin) fit?
    There are a lot off in the bay, also in europe
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,801
    Here is the part # and description for an '05 from the SM-
    OEM: 15373535
    Service: 15373535
    Description: 12-Way F GT 150 280 Series Sealed (GY)
    Hope this helps.
  8. Remove Advertisements
