Cabin Air Filter Replacement
Results 1 to 2 of 2
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Cabin Air Filter Replacement in Cadillac SRX / XT5 Forums; It only took me about 15 minutes and no tools required for 2008 SRX. Here are the steps: 1. open ...
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,066
    1. open hood
    2. remove plastic grill from below the passenger front side (push in the two tabs and rotate up)
    3. push in filter plastic cover on the outboard side and rotate up. This will loosen the other side also.
    4. rotate and twist to remove the filter cover
    5. locate old filter and pull out (some bending / twisting may be needed)
    6. insert new filter making sure that the top of it sits next to the two tabs and is held back by the two tabs in front. You can feel this by hand.
    7. replace covers
    Note: if the filter appears to fall farther down at an angle then you need to take it out and insert it so it sits behind the tabs.
    Hope this helps someone.
    warreneaux is offline Cadillac Owners Fanatic
    Automobile(s): 2006 SRX V8 Black/Black
    Sep 2010
    Houston, Tx
    78
    136
    Re: Cabin Air Filter Replacement
    Awesome..Thanks
    Earl
