unsteady voltage readings
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, unsteady voltage readings in Cadillac SRX / XT5 Forums; Hello Maybe someone can shed some light on this. My voltage readings never stay the same. Now when I say ...
    orandaberg Guest
    Hello
    Maybe someone can shed some light on this. My voltage readings never stay the same. Now when I say that I understand there will be some fluctuations. Mine as normal when starting begins st 12.8 then slowly gies up to 14 but through out my trip to Belgium the readings would go anywhere from 12.5 back to 14 then slowly drip to 13 an back to 14 an so on. My 300C keeps a steady 14.1 with very little fluctuations. On the last leg of my 12 hr drive to Belgium my voltage went down to 12.8 and stayed there till I arrived. 2 days later dead battery. Driving the car daily starts ok with the voltage readings fluctuating between 12.5 to 14 all day. I do not dare leave tge radio o while parked for fear the car will not start. As mentioned in another thread the alternator an battery have tested ok and undsr a load showing the alternator is charging. I am going ti hook my aeoforce gauge back up so I can observe my amps. I read this is another way to test if the regulator on the alternator is working correctly. Do not know if the gm has a regulator on there alternators or if its just the earky model cars that had this. Anyone shed some light on this. Something comes to mind on me is maybe my alternator belt tensioner is going out. Guess I will see that when replacing belts. Anything I should look for in particular when looking at the tensioner, apart from the obvious?
    OakSRX04 is offline Cadillac Owners Member
    Automobile(s): Cadillac 2004 & 2009 SRX V6 AWD
    Dec 2008
    Oakville, Ontario, Canada
    29
    Re: unsteady voltage readings
    My 2009 has the same range. Starts at 12.3, reads 14.8 to 15.2 during typical outings. I asked the dealer if 15+ was damaging my battery and the reply was basically don't worry if the Check Engine light is off. Voltage readings will not tell you about the reserve capacity available. If yours is low you'll have battery problems.
    orandaberg Guest
    Thanks, I have gone over 14, 14.3 max, but if I understand your readings stay at that level, not like mine within an hour it can show up to 20 different readings lasting from a few minutes down to 13, then slowly up to 13.9, stay there a ehile and creep down to 12.8 and go up to 13.5 stay there and go back to 12.8 etc etc etc
  5. #4
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    The ECU or BCM (I don't know and didn't look) control voltage based on charge of the battery and other factors, so it will bounce around. If the battery is charged is there a point in dragging the engine down wasting fuel to keep the volts up?
    Where will you get an amp reading from, not sure it is good data for anything.
    Not saying this is the case but there is a reason why some data is hidden from the owner, people tend to hypochondriac their cars.
  6. #5
    orandaberg Guest
    Ok I can live with the fluctuations then, I shall concentrate on the draw.
  7. #6
    orandaberg Guest
    OK the mechanic went to pick up the car, I left the battery unhooked for nearly 3 weeks and when he connected it it started right up so I assume I can rule out a faulty battery!
    While checking for battery draw, anyone know the acceptable milli ohm draw for the SRX
  8. #7
    orandaberg Guest
    Bump
  9. #8
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,784
    You'll be looking for milliamps. Won't be much and when you pull the offending fuse, you'll know.
    You can isolate the entire rt. or lt. rear fuse blocks at the under hood block. 50A fuses are labeled LPDB 1&2 and RPDB 1&2.
    Been fixin' cars for 74 years
  10. #9
    Mr.electric is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Mar 2013
    80
    I would guess your alternator is starting to fail but has not totally died yet. During your long trip your alternator is charging for the first few hours then gets weak and quits. It would pass any number of tests while it works, fail every test if you tested while it is not charging. If you want to be safe money wise wait until it stops charging all the time. If you want to be safe reliability wise replace it now. Of course I could be wrong and it is some unusual battery computer failure as mentioned in a previous post. I have never been aware of a battery computer in non hybrids but it makes sense. I have seen battery temp sensors on newer 12v batteries those must lead to one of the computers....
  11. #10
    Sep 2007
    2,621
    Almost like they designed it like that
  12. #11
    orandaberg Guest
    Under hood block?(fuse box) So pulling one of those 50A fuses will show which side is drawing current? then start pulling fuse according to side?
    Quote Originally Posted by Mr.electric View Post
    Technically I should be getting a light on the panel, if it fails anytime during operation? There is a DIC indication check charging system if it fails
  13. #12
    Mar 2013
    80
    Quote Originally Posted by orandaberg View Post
    Not if it is charging at low amps as they often do.
    A load test would show voltage and amperage but it does not tell much if the intermittent failure is not happening during the test. I frequently see a car that has dead battery complaint no alternator light. I load test the alternator and find the output is only half or a third of the specification. I proceed to replace the alternator and battery if the battery is bad too. Frequently the battery is damaged after going dead several times.
  14. #13
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,784
    2 50A fuses for each side.
  15. #14
    orandaberg Guest
    Thanks
    Apparently I have no battery issue because I left it unhooked and the mechanic went to pick it up and it started right up.
    Th BCM an ECM apparently control the amount (I think) of out put the alternator works (I read about it but cannot explain)
    So your saying the alternator can test and even under load but be bad
    Hmm I guess since the whole front end is off, it easier to get to the alternator, so maybe to double check is to remove it and take it somewhere to be tested, too late now, it would be 10 days to get a new one
  16. #15
    orandaberg Guest
    No more unsteady reading now that the belt has been changed
  17. Remove Advertisements
